Old 02-21-2014, 03:01 PM   #1
Ray@RDS
Drives: 2010 2SS/RS
Adding the RDS "Maggie Max" blower plates to the TVS2300
I will be doing a complete write up for RDS Blower plates for the TVS2300.
they have been a key part of the Maggie max package offered before.
they come as a complete kit ready for even the "DIY" crowd.
Proven results, reducing actual blower temperatures and keeping IAT's out of the stratosphere.
this kit I will be installing also has a ported and ceramic coated lower tub and a 102mm inlet.
keeping them makes them even better...
stay tuned.
Ray@RDS is offline   Reply With Quote
Old 02-23-2014, 10:51 AM   #2
Jaydog760
Jaydog760's Avatar
Drives: 2013 Camaro SS/RS 1LE
Subscribed....
2013 Camaro 2SS/RS 1LE (black) ** 630rwhp - 590rwtq ** (Mustang Dyno) Maggie TVS2300, OD cog, 3.6 pulley, custom (mild) blower cam, ID850 injectors, ADM FPCM, Cold Air Inductions intake, Melling oil pump, ECS tensioner, Kooks headers, Magnaflow X pipe, Mild to Wild, NPP exhaust, Prosport gauges, Pfadt springs and trailing arms...all installed by Mike and tuned by Ryne @ Cunningham Motorsports
Jaydog760 is offline   Reply With Quote
Old 02-23-2014, 01:00 PM   #3
Slowhawk
Drives: 1999 Trans Am
Just did your 1" spacer on a TBSS 402ci/maggie. Big inlet temp decrease and pulls to 7000rpm cleanly now. Before it would just die off early. Great stuff.
Slowhawk is offline   Reply With Quote
Old 02-23-2014, 01:37 PM   #4
Ray@RDS
Drives: 2010 2SS/RS
Thanks!
They really do stay cooler now, I had the Camaro on the dyno all day last summer down @ Dallas Performance and it never got hot to the touch.
Belt slip is not much of a factor after removing all that restriction under the intercooler either.
Old 02-23-2014, 02:35 PM   #5
H-E
Drives: 2010 zr1 Camaro 2011 vert
Good to hear from ya Ray....
H-E is offline   Reply With Quote
Old 02-23-2014, 02:38 PM   #6
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
He makes the best parts, so you ready for my Maggie ?
2SSRS@Gen5diy is offline   Reply With Quote
Old 02-23-2014, 04:08 PM   #7
Ray@RDS
Drives: 2010 2SS/RS
how they arrive!
Old 02-23-2014, 04:13 PM   #8
Ray@RDS
Drives: 2010 2SS/RS
thx! always ready! will add it to these babies getting ready for spring!
Old 02-23-2014, 06:00 PM   #9
pdiddy
Drives: 2011 2SS
Can I get some info on this what is it that is being done to the Maggie to reduce the iat and what other gains or improvements are associated with the change and pricing?
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
pdiddy is offline   Reply With Quote
Old 02-23-2014, 06:28 PM   #10
Ray@RDS
Drives: 2010 2SS/RS
I designed a phenolic plate to be added between the two manifolds This material isolates the heat of the engine from the supercharger. This allows the intercooler to do its job, which is cooling the incoming air removing virtually all existing heat soak . Raising the intercooler off the floor of the lower manifold also increases plenum volume and removes restriction allowing a clear path to the intake ports. The supercharger is literally cool to the touch pull after pull. All this equals more HP.
Old 02-23-2014, 06:57 PM   #11
pdiddy
Drives: 2011 2SS
Can u pm me a price on this so if I understand this do u just bolt this spacer between the blower and manifold how much does it end up raising the blower I would assume u would have to get a longer belt to compensate or is it to minimal forgive my ignorance on this but I am intrested
Old 02-23-2014, 07:12 PM   #12
Motion427
Drives: 2010 2SS/RS Red Jewel L99
I might know somebody that is interested in this also(spacer)
Could you pm me a $ aswell.if you have some available for sale.Thank you.
Motion427 is offline   Reply With Quote
Old 02-23-2014, 08:54 PM   #13
Neumatic
Drives: 2010 Camaro 2SS M6
Im curious on the price as well.
Neumatic is offline   Reply With Quote
Old 02-23-2014, 09:33 PM   #14
2SSRS@Gen5diy
Is that a LSA blower i see and is that ready to go too?
