01-18-2018, 01:14 PM | #1 |
Drives: 2017 2.0T 1LT Nightfall Gray Camaro Join Date: Jan 2018
How to unplug a drl
Been trying to unhook this for the past few min lol tried pulling and pushing but it won’t comeout anyone know how to take it off thanks, it’s for drl.
01-18-2018, 01:16 PM | #2 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
I’ve had many issues with taking off some plugs honestly it’s just either going to take some time or if your up to it I’ve gotten a flat head and gently stuck it in to wiggle it out a bit but again I wouldn’t recommend because it CAN break something.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
01-18-2018, 01:19 PM | #3 |
Easiest way to do it since I ran into the same issue trying to plug a throttle controller into the Pedal...
1. Pull the red tab up. 2. Get a PLASTIC tool that is durable and won't destroy the connector 3. Slowly rock the connector while pushing the tool between the 2 connectors. It should come loose eventually...this is what I did with my stuff.
01-18-2018, 01:54 PM | #4 |
Thank you guys, I was able to unplug it safely.
