12-13-2017, 09:43 AM | #1 |
Drives: 2016 2SS Ragtop Garnet Red Join Date: Sep 2016
Trunk Divider recall - check yours if you've had it done
My 2016 was in for service this week and they replaced the divider in the trunk (piece that separates the top storage area from the trunk storage area when the top is down).
Got home and realized that, if you push on the divider at all, it will not stay up. Pops right off the top mounts. You dont have to push hard on it at all - the pressure of a bag sitting against it when you hit the brakes would cause it to fall. Went right back to the dealer today so the service manager and I could look at it. He brought his interior tech out as well to make sure it was installed correctly (not much you could do wrong really). They still had the original so we put it on - you could push on it so hard it looked like the grommet was going to come out of the divider and it would not come loose. In fact, they pushed on it until eventually the bottom grommets popped off but the top ones never came loose. Put the new one back in and any pressure on it at all would make it disconnect from the top and fall. They both agreed something was wrong with the new one so they pulled another out of inventory - it did the same thing. They could not find anything different about the new ones visually but clearly something has changed with the replacements. Go check yours if you have had it done and please post what you find. I dont know if its a bad batch my dealer has or a global issue. If you dont use your trunk much you may not notice it but, if you ever take a trip and put a bag or two in the trunk, you will have to get out and put the divider up EVERYTIME you want to operate the top. For now my dealer put my original back in and left the recall undone as the fix is going to cause more problems than the original. But if this 'new' design is here to stay, Im going to take extra care of my original because the new one seems to be a step back. |
12-13-2017, 10:17 AM | #2 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
Interesting, never had an issue with the original as of yet. Certainly will shy away from running out and getting the recall done for sure. Thank you for the heads up!
12-13-2017, 06:23 PM | #3 |
Drives: 2016 2SS Convertible Join Date: Oct 2017
You are correct!
I had the TSB done right before Thanksgiving and I have not driven the car but a few miles since then. But, I just now went out to the garage and checked. The partition pops off the posts without much effort. Not good. --KLG--
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
12-13-2017, 08:08 PM | #4 |
Drives: 2016 2SS Convertible Join Date: May 2012
I know a person locally that had the same problem with the replacement on his car.
12-14-2017, 07:17 PM | #5 |
Drives: 2017 2SS Auto Join Date: Apr 2017
Me too. Thought it was only my car. I wonder if that was a design change to make it easier to push down the partition?
12-14-2017, 08:26 PM | #6 |
I think its an error on their part. I think they had to change the grommets because the sensor couldnt sense them in some instances. The new grommets on the replacement seem to have a shallower gap, causing the plastic clips that are supposed to hold it on not to engage completely. Chevy needs to fix this or they are going to have a lot of complaints on their hands.
04-16-2018, 07:55 PM | #7 |
Drives: 2017 Camaro 1LT Convertible Auto V6 Join Date: Jul 2017
TSB Number 17209 Performed April 6th and just noticed that the new part will not snap in all the way on the passenger side grommet/fastener, threw a lunch box in the trunk and the whole partition came down. Back to the dealership and see what they say
05-08-2018, 09:12 AM | #8 |
Drives: 16 2SS Convertible, 08 JKU Join Date: Jan 2016
I had my car in last Wednesday for a routine oil change. The dealer ordered the recall partition. Went this morning to pick it up and the dealer service manager said he had to install it. I asked if I could keep the original divider and they said no. Based on the information in this thread I elected not to have the tsb done. I haven't had any issues with the original one so I didn't want to risk "breaking" something that currently works.
'16 2SS Convertible - Blue Velvet, 6M, MRC, NPP, 56R, Nav, Ash Gray, & Silver Rally.
'08 Rubicon JKU - Jeep Green, 6 spd, 5" Terraflex, LoD Off-road armor, Warne 9.5, 4.88 gears, 37x12.5R17 |
05-08-2018, 05:15 PM | #9 | |
05-08-2018, 07:01 PM | #10 |
Agreed that the replacement is junk. They replaced mine and it is definitely not as good as the original.
06-01-2018, 08:17 PM | #11 |
Drives: 2016 Nightfall 2lt 3.6 convertible Join Date: Dec 2016
I was having problems with mine in the fall
Sometimes the top would not work at all I’d have to go take everything out of the trunk And it would work Car was in for an oil change and they changed it No problem Until this week I had some groceries in the trunk and it fell Did think anything of it until I read this thread I’ll be watching now |
06-02-2018, 06:41 PM | #12 |
Drives: 2016 Camaro Convertible 2SS Join Date: Nov 2016
Thanks for the heads up on this. Took my 16 2SS in for last of the free oil changes (why they put 8.8 quarts in a car that calls for 10?) and the CSR mentioned this recall.
Fortunately, the part was not in stock as he had replaced one earlier in the week. Not been having issues and I use the top a lot. I will have to think on this one long and hard as I keep my helmet, emergency kit and autocross numbers in trunk pretty much 24/7.
2016 2SS Convertible, A8, Dual mode exhaust, MRC, Nav, Stainless pedal kit, all-weather mat upgrade, SS center caps, Hurst billet shift handle, Camaro logo armrest
06-14-2018, 09:52 AM | #13 |
Drives: 2016 2LT-RS, A8 Kalhari 'Vert Join Date: Dec 2017
I checked with my Dealer
Based on my VIN he said there was no recall. I've a 2016 RS-2LT?
RPI Design Front Splitter, Diode Dynamics Side Markers, RS-Summit White SEMA grille, MBRP Quad Exhaust, GM Dark taillights, Hurst Pistol Grip automatic shifter, Big Worm Graphix stripes
American Authority (Side Skirts, Diffuser & Valance, Tow Hook, Front Fender Vent, Side Scoops) |
07-16-2018, 03:17 PM | #14 |
Drives: 2017 2SS M6 Vert Summit White Join Date: Jul 2018
I'm guessing my 2017 came with the "improved" divider. A swell water bottle caused it to fall.
