11-30-2017, 05:52 PM | #15 | |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
hope all goes well this weekend!
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
11-30-2017, 06:54 PM | #16 |
Drives: 2017 1LE - Blue Join Date: May 2017
11-30-2017, 10:09 PM | #17 |
Drives: 1LE Join Date: Sep 2017
Hopefully all works out and I'll purchase and have Andy align. http://www.phoenixperformance.net/ph...aquilante.html
11-30-2017, 11:23 PM | #18 | |
Drives: 2017 1LS White Join Date: Oct 2016
12-01-2017, 10:26 PM | #19 |
12-02-2017, 08:17 PM | #20 |
Everything went perfect today and I had no issues at all with the camber plates. I also tried the no lift shift today for the first time and it works great.
12-02-2017, 09:34 PM | #21 |
Good to hear. Whats your alignment number if you don't mind.
No lift shifts? I missed this. Details please! |
12-02-2017, 10:53 PM | #22 |
No problem I don’t mind. The front is -3.5 camber with 1/8” toe out and the rear is -2.5 camber with 1/8” toe in.
For the no lift shift I saw the thread a week or so ago in the “ask Al” section. When you’re WOT and at 5k or above RPM you can shift while WOT. I need to do some more looking into it because in the HUD it flashed green, yellow, or red. The only thing that comes to mind is it’s telling you how close the shift is to redline. |
12-02-2017, 11:07 PM | #23 | |
Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
12-03-2017, 01:59 AM | #24 | |
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
12-03-2017, 07:54 AM | #25 |
12-04-2017, 09:40 AM | #26 |
Drives: 93 RX-7, 17 SS 1LE, 04 RX-8 Join Date: May 2017
When I was messing with my rear alignment I was able to get quite a bit of camber out of it. North of -2.5° IIRC. The problem is that the factory toe adjustment doesn't have enough range to compensate and get the toe back in order. I think with adjustable toe links alone you should be able to get that.
12-04-2017, 02:45 PM | #27 | ||
12-05-2017, 12:33 PM | #28 | |
Wow!! Thats an amazing amount of rear camber!! Like austrailian v8 supercars level amounts!
