06-22-2017, 06:46 PM | #1 |
Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
ZL1 1LE- When can we get ahold of those DSSV's?
After watching the video today, Im absolutely floored at the performance of the ZL1 1LE.
I didnt own a 5th gen but could someone fill me in on how it worked with the Z28 package being released? Do you think GM will offer a similiar package for us SS and 1LE guys to swap? If so, what was the time frame from Z28 release to release of the suspension package? |
06-23-2017, 07:16 AM | #2 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
If history repeats itself, GM will offer a ZL1 1LE kit with everything (springs, shocks, seaybars). This is one reason I opted for the non-MRC shocks. I'm hoping within a year it's released. We'll see.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
06-23-2017, 09:38 AM | #3 |
Drives: ZL1 1LE Join Date: Oct 2016
Did they offer adjustable spring rates? You will very likely need different spring rates if you are trying to use these on a regular SS compared to a ZL1.
06-23-2017, 02:07 PM | #4 | |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
Anyway, I sure hope they do because I will probably jump on the DSSV train if they are not tooooo expensive and the kit offers a MRC defeat like the KW V3 does. |
06-23-2017, 08:22 PM | #5 |
Are the spring rates on the SS 1LE and base ZL1 the same?
06-24-2017, 07:53 AM | #6 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
Hopefully theyll just release the shocks and struts/springs by themselves.
Shouldnt be mich an issue on the spring rates. The v6 1le uses fe3 ss springs.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
06-24-2017, 08:13 AM | #7 |
GM Performance Parts will be at CamaroFest next month.
Lots of good questions to get answers for very soon. |
06-24-2017, 12:58 PM | #8 |
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
The weight difference shouldn't be that much different since the new ZL1 1LE is about 70 lbs lighter than the ZL1 and with 19" wheels. However, the rear spring rates might be a bit stiffer since it has a wing. As I am planning to combine these DSSV suspension with very sticky rubber, having even higher spring rates is even beneficial
06-27-2017, 07:27 AM | #9 | |
Drives: 2LT/1LE, HPCRX, F250(tow vehicle) Join Date: May 2016
I guess I could just have a GM parts guy look up the part number for some replacement springs (if available) and see if they're different.
2017 2LS 1LE
'I feel that life is measured in achievement, not in years alone' Bruce McLaren |
06-27-2017, 09:16 AM | #10 |
Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
It looks like they're just standard 2.5 ID race springs, so re-springing shouldn't be a problem if you wanted to tweak spring rates.
06-27-2017, 12:34 PM | #11 |
Drives: Red Hot track candy Join Date: Oct 2009
In chatting with a race shop (LGR) they mentioned GM generally makes only one spring rate per application. Isn't the spring rate primarily there to adjust ride height or is it critically important to match with valving? They said Moton might be a better option for a switch from mag due to the greater range of adjustment over all aspects.
Baby born 11/08/16. Left birthing place 11/25/16. Arrived home 12/6/16: '17 Red Hot ZL1. Stock.
06-27-2017, 01:18 PM | #12 | |
Spring rates funcutions are for much more than ride heights. Spring length is more applicable for overall vehicle height. Spring rates biggest impact is related to dynamic handling. For instance, it is the spring rate that primarily dictates how much dive (front springs) there will be under heavy braking or how much load transfer (front to rear) happens when you're trying to accelerate out of a corner. Also, the damper's valving has a pretty wide window related to how much spring rate will work in any given application, so it isn't a big deal to change spring rates... I've done previously. As for the race shop recommending Motons versus DSSV's. First off, just be mindful when taking advice from anyone that also sell parts... just putting that out there. Also, Motons are good race dampers, though adjustable parts are only as good as the person tasked with the adjustments. I've seen too many guys spend big $$ on adjustable race dampers to only end up with a car that is a hot mess dynamically because they get it to the track and are fighting the car and don't know what to change... and can't get the car to behave how they want. The DSSV's are absolutely state of the art technology (motons decidedly old school by comparison) that are designed specifically for our platform's most hard core track package. I'd also want to compare cost before deciding either way. |
06-27-2017, 03:46 PM | #13 | |
I just checked with em today, not even 1 hour ago about the FEA suspension code (Fe2, Fe3, Fe4, and now FEA for the ZL1 1LE..) nothing out about it yet on the parts lookup they use from GM. I was actually checking to see if the lower links with spherical bearings are the same on the ZL1 1LE as the FE4 ZL1 and the 1LE packages.
06-27-2017, 03:57 PM | #14 | |
