Old 03-24-2017, 10:32 AM   #29
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Mine were machined in KC by a machinist that Mike uses. He is a Race Star employee. I picked them up from Mike after the machining. They were machined from the 6.00 standard wheel. I originally started with the 6.8 bs wheels but the spokes hit the calipers and I was concerned the 6.00 would have been too close to the fenders. That's how the 6.43 bs wheel came about. As you can see with Prays tires they are very close to touching the fenders on the launch and his car is stock ride height.
Ah that makes sense then. Mike and I have discussed custom coating options too... Good deal.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 03-24-2017, 10:35 AM   #30
Pro Stock John
Writer
The RS lugs are tight, and in my experience it's a bad idea to use an impact for the first couple of on/offs. I always suggest to customers they put some oil or lube on the studs for the first time.
I tell folks to put wheel on, get lugs going, and go 'round and 'round.
PROJECT HEAVY CHEVY
Old 03-24-2017, 10:42 AM   #31
ULTRAZLS1
ULTRAZLS1's Avatar
I use all the rings also. I've had no problems with the lugs as you just have to run them down slowly a little at a time and I torque at 130 lbs.
Wow I thought torque on these were supposed to be ~90?
Old 03-24-2017, 11:10 AM   #32
PRAY
PRAY's Avatar
Drives: 2016 2SS
It's actually 140ftlbs. 14mm lugs.
Old 03-24-2017, 12:45 PM   #33
ULTRAZLS1
ULTRAZLS1's Avatar
Well damn I better tighten them up a little more this year lol
Old 03-24-2017, 01:58 PM   #34
mustangcrusher1
mustangcrusher1's Avatar
Drives: 2017 camaro SS blue w/white stripes
are all race star wheel for the 6th gen uni lug or are they direct drill?
mustangcrusher1 is offline   Reply With Quote
Old 03-24-2017, 02:39 PM   #35
DapperDan
DapperDan's Avatar
Drives: 2017 1SS A8 Nightfall Gray
Called Summit they had no problems sending me 2 hub centric rings and some washers so that's cool. Ok so back to picking you guys brains.when you get a tire monitor light on ,does it affect any other functions like speed or rpm ,traction control or launch control ? I don't wanna drive to the strip with the light on and then not be able to go over 30mph or 2000rpm or some crap like that...not worried about launch and traction control not gonna use em at the strip anyways ,Also do any of you guys know that part# for the TPMS sensors?
DapperDan is offline   Reply With Quote
Old 03-24-2017, 06:24 PM   #36
Tim Adams
Tim Adams's Avatar
Drives: 2020 Elkhart Lake Blue 1LT Z51 C8
SS TPMS is 13598787.
Make sure it is the SS sensor if you get them, they are SS specific.
Ordered-Hyper Blue 1SS, A8, NPP, 56W wheels Built 1/20/16
Delivered 2/12/16!!
Sold 9/17/19 :(
2020 C8 ordered!!
"The greatest sound in the world is a Rolls Royce Merlin over 100 inches"
www.timadamsphotography.com
Tim Adams is offline   Reply With Quote
Old 03-24-2017, 07:08 PM   #37
hotlap
hotlap's Avatar
FYI - I bought a set of sensors for my winter tires and discovered the mounting hardware wasn't included (seal, collar, cap). Kit 13507403 contains parts to install four.
Ronald Reagan -
Old 03-25-2017, 07:02 PM   #38
DapperDan
DapperDan's Avatar
Can't wait for the rest of my order to get here because my 60ft on stock tires sucked at strip today 1st and best pass 1.904 60ft ended up 12.45 /113.97 disappointed with ET but MPH is promising for being hot and humid,does anyone know the DA for Mason Dixon dragway in Maryland today between 1 and 3pm
Old 03-25-2017, 07:24 PM   #39
hotlap
hotlap's Avatar
Drag times says at 1:53 pm is was 75.9 degrees, 43%, 30.17 in. Here is the DA
Ronald Reagan -
Old 03-25-2017, 07:26 PM   #40
PRAY
PRAY's Avatar
Drives: 2016 2SS
Originally Posted by mustangcrusher1 View Post
Pray what size BS are you running? 6.00 or 6.43BS? are you running 28" tall DR too?
6.00 and the tire says it is 28" tall but it's not when it's on the car. It is right at 27".
Old 03-25-2017, 08:06 PM   #41
DapperDan
DapperDan's Avatar
Thanks I've never really knew much about the DA stuff until I started reading about it on here I just knew you didn't run as well the hotter it got. So what should my expectations be with a full drag pack and 0 DA ?
Old 03-25-2017, 08:26 PM   #42
ULTRAZLS1
ULTRAZLS1's Avatar
Totally stock with 17" drag pack and skinnies in the front ?
If so in zero DA should be good for 11.8-12.0
But it's hard to compare tracks even with the same DA some are just faster than others.
My car ran 11.80 in around zero da with drag pack cai and ptb with my 250lb ass in the seat. My 11.68 run was -400 DA and the low fuel light on.
In crazy negative DA with nothing but a drag pack and a small driver I believe these cars are capable of about 11.5. Much more and I'd have a hard time believing it.
