02-24-2017, 08:25 PM | #1 |
Only 6spd manual in the new ZL1 1LE?????
I really like the look of the new ZL1 1LE, but no 10 spd auto will likely make my choice much easier. As much press as the new auto 10spd has had in the last few months, you would think it would be available. The Z06/Z07 has the 8spd auto available. Looks like my new ride may be a ZL1 with 10spd auto and an r comp tire upgrade with racing brake pads.
02-24-2017, 08:30 PM | #2 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
Maybe the new A10 isn't as track capable as they wanted. There really is no point in not including it on the ZL1 version, unless it was slower.
02-24-2017, 08:37 PM | #3 | |
Drives: New : 2017 SS 1LE Old: 2012 TTRS M6 Join Date: Oct 2015
. https://www.wheelwell.com/profile/56...ed9c3a/garage/ . . Project 1LE Wraith: http://www.camaro6.com/forums/showthread.php?t=474068 Last edited by aa406079; 02-24-2017 at 08:52 PM. |
02-24-2017, 08:47 PM | #4 | |
I used to be Dragoneye...
My theory is that the manual offered less heat generation, and decidedly lighter weight. Compared to an automatic ZL1...the ZL1 1LE will be 100 lbs lighter. That's significant! |
02-24-2017, 09:11 PM | #5 |
Drives: 1970-1/2 Z-28, 2017 ZL1 Join Date: Sep 2012
i think everyone is underestimating the M6. It is not your "grandmother's manual". The couple of folks that have driven mine love the gearing of the new M6 matched up to the torque band of the LT4. I can't shift as fast as the A10 but on most tracks I wont have to shift as much as the A10 will need to and that is where I think the M6 will shine.
02-24-2017, 09:26 PM | #6 |
Drives: 2010 CobaltSSTC Join Date: Sep 2015
Would be nice to know if there are differences between the M6. Hopefully it's the exact same.
02-24-2017, 10:28 PM | #7 | |
Drives: 17 SS 1LE Join Date: Dec 2015
It's ok if there are Camaros that do certain things better than your 10AT ZL1. No loser in the lineup. |
02-24-2017, 10:42 PM | #8 | |
It just kinda irks me that some folks will arbitrarily dismiss that this A10 is properly fast. In the same sort of way that it bothers me how some folks pretend the M6 is a fossil. |
02-25-2017, 07:32 AM | #9 |
Romans10:9-13
Drives: /\yes, this is me/\ Join Date: Nov 2008
My guess would be that since the mission of this new ZL1/1LE is the track, they dumped the A10 to keep the heat soak down to maintain the LT4 power. Possible use the coolers elsewhere
02-25-2017, 12:59 PM | #10 |
Drives: 2013 ZL1 M6 Join Date: Oct 2013
Heat, weight, and for most tracks too many gears. Most tracks even with a 6 speed manual, you use 2 or three gears, at most 4 if there are some long straights.
02-25-2017, 01:11 PM | #11 |
Romans10:9-13
That is very true
02-25-2017, 01:26 PM | #12 | |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
In the past 100-some years, 3-pedals has gone from de facto to gradual inconvenience to tiny minority. The only reason they're still around is because of a tiny few that want the visceral experience. If anything in the past couple years they've become a rite of passage. There will always be the people that need to prop themselves up to feel better by discounting others. That's not what a healthy community is about. It's about celebrating choice and diversity. GM offering their 6th gen Camaro 1LE's, regardless of engine, with manual-only, means that 1LE = manual. That's their decision. None of that will stop an A10 ZL1 owner from adding 1LE bits as they see fit.
02-25-2017, 05:19 PM | #13 |
Drives: 2017 Camaro 1SS 1LE Join Date: Jan 2017
I think something that tends to get overlooked in these "discussions" has nothing to do with the times that the auto or manual is capable of. It is that cars with a manual transmission are just going to be able to run hard for longer at the track, whereas the automatic transmission is going to have a tendency to get hot and need to take a break earlier.
02-25-2017, 07:50 PM | #14 | |
