Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > V6 Bolt-Ons & Tunes
Old 12-30-2016, 08:19 AM   #1
RPI Designs
RPI Designs's Avatar
Drives: 2016 SS 6 Spd
Camaro V6 Borla ATAK Axle-back 11929 Non NPP Single Tip
2016-2017 Camaro V6 Borla ATAK Axle-back 11929 Non-NPP Single Tip $753.99
When it comes to exhaust system you have got to put Borla at the top of the list when it comes to quality and performance. Borla designs their exhaust products to ease the stranglehold your stock exhaust system has on your vehicle's engine. Borla's patented technology opens the way for escaping gasses, and maximum exhaust flow equals improved performance. This translates into more power and torque when you plant your foot, along with increased fuel economy at cruising speeds.
Borla builds its exhaust systems from aircraft-grade T-304 stainless steel, so they're lighter, stronger, and last far longer than factory exhausts - all with easy bolt-on installation. Extensive research determines which tube size will get the most performance from your car or truck. Smooth mandrel bends and efficient design give the exhaust a mellow rumble while keeping most of the sound behind the exhaust tips. This means you won't get unwanted droning noises in the cockpit while cruising. Every Borla exhaust system gives you precision fit with motorsport-inspired styling, all backed by a million-mile warranty against defects in material or workmanship.
This high-performance replacement exhaust system includes all parts and hardware required for installation (some factory original parts may be re-used).
Rear Section ATAK Dual Exhaust System
2.25" into muffler dual 2.75" out
This system is for vehicles that come from the factory with single tips are not equipped with NPP (dual mode exhaust).
Fits Automatic/Manual Transmissions
Fitment: 2016, 2017 Camaro V6
https://www.rpidesigns.com/shop/item...pp-single-tip/
RPI Designs is online now   Reply With Quote
Old 07-29-2018, 11:18 AM   #2
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
RPIDon is offline   Reply With Quote
Old 11-06-2019, 02:35 PM   #3
RPI Designs
2016-2018 Camaro V6 Borla ATAK Axle-back 11929 Non-NPP Single Tip $753.99
