12-09-2017, 02:09 PM | #1 |
Drives: 2018 1LT Camaro Join Date: Aug 2017
Window question?
Does everybody's Camaro do this?
When you shut the car off and open the door both sides. The window drops down about 1/4 " maybe a little less. When you close the door the window goes back up. It's a 2018 1LT. Thank You |
12-09-2017, 02:14 PM | #2 |
Bannable
normal. Keeps you from shutting car door against cabin pressure.
One must forego the self to attain total spiritual creaminess, and avoid the chewy chunks of degradation
2017 ZL1 A10 - Hyper Blue Metallic Rotofab CAI, TM ported TB, AWE non res touring catback with PLP's |
12-09-2017, 02:16 PM | #3 |
Drives: 2017 Camaro 2SS / 2012 CBR1000RR Join Date: Jul 2017
Yes, the design of the windows requires this. I can't find any documentation, but I think it has to do with the proper closing of the door, and then provide a good seal between the window and the weatherstripping.
12-09-2017, 02:18 PM | #4 | |
Bannable
On cars that do not do this you will often find a vent with a one way flap to vent cabin pressure when the door is shut.
12-09-2017, 02:18 PM | #5 |
Drives: 2016 SS w/2SS A8 Blue Velvet Join Date: Dec 2009
It’s called venting. Makes it easier to close the doors with such a good seal within the cabin.
Never grow up, it's a trap!
12-09-2017, 02:30 PM | #6 |
I thought it was messed up since I never had a car that did this.
Glad it's normal. |
12-09-2017, 02:33 PM | #7 |
Bannable
I have never disconnected the battery on my Z, but on my vette I had to reset the window indexing after disconnecting the battery.
12-09-2017, 02:34 PM | #8 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
It has to, the only way to clear the lip and seal tight.
12-09-2017, 02:34 PM | #9 |
Retired from Car mfrs....
It will be same as vette
12-09-2017, 03:57 PM | #10 |
Drives: 2017 2SS Summit White Camaro M6 Join Date: Mar 2012
Check out your manual. It will answer a lot of questions!
12-09-2017, 05:32 PM | #11 |
Drives: 2017 Camaro 2SS, A8 Join Date: Aug 2017
I was told by the tint shop it's called window indexing. Most high-end coups have it.
12-09-2017, 07:17 PM | #12 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
Yep. it's supposed to do that
12-10-2017, 09:49 AM | #13 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
Yes, it's called indexing glass.
It's primary purpose is for sealing the glass at speed on a header-less door. In the old days, there was what was called "blow out" clip on the seal but at speed, the pressure differential would push the glass out and off the seal. In the old seal designs you tried to hold the glass against the seal. The ideal state is like a door with a header where you can capture the glass for better sealing. Earlier improvements were done by tipping the glass. This allow the glass to "stand up" into the seal when you closed it. When you opened the door, the glass would tip in ward and down so you could pull it off the seal. Later designs in the last 10 years or so use indexing to have the regulator drop the glass just a pit out of the seal so you could then easily open the door. Yes, it does provide some pressure relief for door closing efforts, but the main reason is to have a good glass seal. Corvette at least looked at indexing both windows when the hatch opened to improve hatch closing. But last I knew, you had to open the windows significantly to make enough of a difference. Not sure if that ever made it to C7.
