12-05-2017, 02:14 AM | #15 |
Drives: 2017 Camaro SS Summit White Join Date: Apr 2017
I have this issue too on my 2018 as if anyone can tell me where to add the foam tape that would be awesome
Sent from my iPhone using Tapatalk |
12-07-2017, 06:28 AM | #16 |
Drives: 2016 Camaro 2SS Join Date: Jun 2016
Li'l help?l Where does the foam tape go?
12-07-2017, 08:32 PM | #17 |
Drives: 17 SS 1LE, 02 GTP Join Date: Jan 2017
I just put the tape along the top between the mounting hooks.
2017 Mosaic Black Metallic 1LE
12-07-2017, 10:42 PM | #18 |
02-10-2018, 07:05 PM | #19 |
Drives: 2017 Camaro 2.0 RS Join Date: Jun 2017
I cant find the info ?
I know someone posted some pics of taking the radio off to put foam tape behind to quiet rattle, but for the life of me I cant find it now?
Anyone with better locating skills got the link? Thanks |
02-10-2018, 07:20 PM | #20 |
I didn't have to remove anything, just put foam behind the upper bezel, in the middle. It's been fine since then.
02-10-2018, 07:39 PM | #21 |
Behind ?
There is no place to put anything behind, unless your leaving it viseble to the eye?
I saw somewhere someone took a panel off the bottom, two screws and you can get behind the unit and hide some tape or whatever to stop the rattling. But now cant find that post. |
02-10-2018, 07:46 PM | #22 | |
Drives: 2016 Camaro SS Vert. Join Date: Apr 2017
02-10-2018, 08:36 PM | #23 |
I have the 8" screen. There's the plastic bezel that arches over the screen; behind this there is a slit that you can put a little piece of foam or padding into (you don't need much). At first I would cut the foam a little big so you can try it first so see if it gets rid of your rattle, then you can trim later.
02-12-2018, 03:26 PM | #24 |
Drives: 2017 SS 1LE SIM Join Date: May 2017
I have this same problem, but like someone else said, i cant fit anything on the top sides or bottom of the screen besides a business card. How do you get the screen off without making it worse? Pictures would be very very helpful.
02-12-2018, 04:07 PM | #25 |
Drives: 2016 2SS, Summit White, A8, NPP Join Date: Apr 2013
This thread has a video that shows removing the radio piece and you can see the hooks.
http://www.camaro6.com/forums/showth...ghlight=rattle |
02-12-2018, 06:39 PM | #26 |
Drives: 2016 Camaro 1SS, M6, NPP Join Date: Jan 2016
I just told my dealer during an oil change visit and they took care of it. No more rattle.
02-12-2018, 09:59 PM | #27 |
https://www.dropbox.com/s/zielgud13s...00102.jpg?dl=0
This is a view from above the screen; I have a piece of velcro inserted (not trimmed yet) |
02-13-2018, 08:01 AM | #28 |
Drives: 2016 SS Join Date: Mar 2016
My 16 SS with 14,000 miles has never had a single rattle anywhere. My 17 LT has rattled like a coffee can full of marbles since day one. The drivers door panel rattles with the slightest bass beat, and I have a rattle that seems like it’s coming from the grill area in the center top of the dash, even though I can’t seem to figure out where it’s actually coming from. So far I can’t push, pull, or find any way to make it stop. I’d hate to have the monkeys at the dealership dig into my dash! That would surely cause more issues than it would fix!
