Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 12-07-2015, 08:51 PM   #1
The_Raging_Bull
Raging Bull Reborn
The_Raging_Bull's Avatar
Drives: '09 CGM Z063LZ '15 RH Z/28 #0631
275/40R20 on all four corners
I used search and found at least two thread's on point to my question:
http://www.camaro5.com/forums/showthread.php?t=264134
http://www.camaro5.com/forums/showth...dth+oem+wheels
My question is that a friend just offered me a brand new set of alloys off of a '12 SS Vert which are identical to what I've currently got on my 2SSRS. They were brand new when pulled with zero road rash (he bought a '12 with 4000 miles!
Consequently I can replace my front wheels with these larger 20 x 9 alloys and run Pirelli-PZero 275/40-20's on all four corners. I know from the thread above that folks are doing it, just wanted to make sure there we're no issues as it does sound like 275's on all corners allows you to rotate the tires.
Thanks for the help
Toy 1 '15 RH Z/28 w/AC & Radio S/N 0631
Toy 2 '09 CGM Z06 3LZ
My DD: '17 Ford Mustang GT
Her DD: '14 F150 Ecoboost 3.5
The_Raging_Bull is offline   Reply With Quote
Old 12-07-2015, 09:15 PM   #2
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
No issue only improves driving/cornering dynamics
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 12-07-2015, 09:22 PM   #3
oldfriend
Drives: Fiat 500 E
All kind a problems !
The biggest one however is that since then I have to rotate the tires about 5K miles , what a pain , when before that I had nothing to do regarding that , just kept on driving till the wheels came off , ( well , the tires )
Other than that , it's all good
oldfriend is offline   Reply With Quote
Old 12-07-2015, 11:35 PM   #4
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
It's been done by a lot of us. I'm hopping on the bandwagon soon as well, once I wear out my front tires I'll be looking for a rear set of rims to match up with a set of 275 tires. Being able to rotate the tires is also a big plus for me lol
Current: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower w/ Idler Relocation, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, Tuned by Pat G
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 12-08-2015, 01:23 AM   #5
L99CAMA2011
L99CAMA2011's Avatar
Drives: One of the baddest handling Gen 5s
Thanks for the help
106 load rating tires on all 4 corners will make your car a high speed corner king with tons of tire support for that 3800lb beast. It is heavy but actually a very good setup. If only you had lighter rims. Go for it.
L99CAMA2011 is offline   Reply With Quote
Old 12-08-2015, 06:46 PM   #6
The_Raging_Bull
Raging Bull Reborn
I got the rims today, and am going to mount 275 PZero's all the way around. Too cool, thanks for the reply. This is the same size rubber my Z06 has on the front.
The rims were brand new and a deal at $500 for all 4, they were pulled off when the car was new and put in the boxes of the custom chrome rims that were on the car.
Old 12-08-2015, 08:30 PM   #7
JewelSS
Norcal Camaros
JewelSS's Avatar
Drives: 2010 Red Jewel 2SS L99
Did this to mine a while back and aside from the stiffer feel in the steering wheel its all good. Amazing difference in the corners and way more overall feel of the car.
Blaque Diamond Wheels BD23's 20x10, Hankook V12 275, AAC footwell lighting, Switchback LED's, AAC Mailslot scanner, AAC underhood, grill & underbody led lighting, AAC Plasma fogs, Eagle eye HIDs, RJT Painted calipers, RJT painted engine bay, Viteese Paddle Shifters, CFD Hurst style Shifter, RJT painted speedo & gauge trim, RotoFab CAI, TSP 2" Headers with full 3" XS Power exhaust, Granatelli Slotted rotors & Hawk HPS pads, ACS Side Rockers, ACS Front splitter, ZL1 Grill, Havoc Rear diffuser, BMR 1.4 Springs, BMR Strut tower brace, BMR F/R Sway Bars, BMR Trailing Arms,
JewelSS is offline   Reply With Quote
Old 12-09-2015, 12:41 PM   #8
Tmick5jr
Todd
Tmick5jr's Avatar
Drives: 2012 Camaro
i run that setup except with a 10 inch wide zl1 rim. The fronts hold up great but the tail likes to slide out a little too much, could use a slightly wider tire in the rear
Tmick5jr is offline   Reply With Quote
Old 12-13-2015, 06:41 PM   #9
Lonewolf583
Apex Predator
Lonewolf583's Avatar
Drives: 2010 2SS/RS M6 Rally Yellow
IMO...275 sq on a oe 20x9 is the best bang for buck mod you can make to an SS. It won't be 1LE quick but it'll be far closer to neutral. Although...personally I'd go with a conti dw or mich pss over the p0s.
2010 Camaro 2SS/RS - LS3/TR6060, Paid Off \o/
Beating physics into submission since 1991.
Lonewolf583 is offline   Reply With Quote
