05-05-2022, 10:26 AM | #1 |
Drives: 2019 camaro V6 Join Date: Nov 2019
Weird exhaust shit
So I have a v6 camaro and I’m doing a straight pip on it but I noticed a valve in the middle of the exhaust not doing anything but it has a spring holding it shut. However because the straight pipe it’s floating open and vibrates and makes an annoying noise. I’m considering welding it open or cuting it out but does anyone know what the purpose of the valve is (it’s not an npp exhaust)
05-05-2022, 01:50 PM | #2 |
AFM valves. Active Fuel Management valves, when it switches to 4 cylinder mode. My guess but I could be wrong.
05-05-2022, 06:15 PM | #3 |
Drives: 2022 ZL1 M6/Nissan Leaf Join Date: May 2016
Based on the title, I thought this was a thread about Taco Bell...
05-05-2022, 10:24 PM | #4 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
If that were the case, the valve would be stuck open and act like straight dumps....
05-06-2022, 06:43 AM | #5 |
oh the imagery
05-06-2022, 08:19 AM | #6 |
05-06-2022, 01:41 PM | #7 |
05-06-2022, 02:51 PM | #8 |
Drives: 2008 Corvette Z06, 1991 Mustang 5.0 Join Date: Feb 2022
05-06-2022, 02:56 PM | #9 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
05-06-2022, 03:02 PM | #10 |
OP's username is a perfect Taco Bell match, too Alas, my serious mood all but turned into vapor the moment I saw "straight pip".
Sorry OP, promise I won't troll further into your thread.
05-06-2022, 04:01 PM | #11 | |
“DUMPS”!!
05-08-2022, 12:57 AM | #12 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
the spring activated afm valves do not throw codes nor have any sensor or electronic features that could throw a code. all they do is react to pulses from v4 mode to muffle them so v4 mode is smoother sounding. without them v4 mode sounds obvious (to those within the car)
you can remove them just fine if you want. but straight pipe and the lgx make for a poor sound and horrible quality of life driving for any amount of time but it's your car. |
05-09-2022, 12:59 PM | #13 |
Long hauler
Can confirm about the spring valves not throwing codes. Mine started making noise like yours and I had them cut out without issue. I do have AFM tuned out so I don’t need them anyways.
2016 1LT v6 - Totaled Happiness: Infinite |
05-29-2022, 02:02 PM | #14 |
Drives: 23 2SS 1LE Join Date: Feb 2019
I want cut cut mine out but was going to (steel) zip tie them temporarily to make sure there wernt any noticeable issues. Is there a certain way to do it properly to make sure they remain fully open?
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 Black on black 2019 3LT RS Camaro. 1100: 3/7/19 | 4200: 4/15/19 3100: 3/15/19 | 4800: 4/23/19 3400: 3/22/19 | 5000: 4/25/19 Built: 4/8/19 | Home: 4/26/19 |
