TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 07-04-2010, 08:03 AM   #1
hatter69
Drives: 2010 LT1 Black Vin 366
Programming Key FOB
Key Fob Fix
Misplaced one of my keys and never found it. Ordered a new one ($50). Dealer wanted 1 hour labor ($50) to reprogram or sync the buttons to my car. Found the below fix online and 2 minutes time I was done!
April 15th, 2010 at 4:33 pm, Andrew Hughes Says:
1. Close all vehicle doors.
2. Insert the key into the ignition.
3. Hold down the power UNLOCK button on the driver’s door panel(CENTER FOR US CAMARO OWNERS)-continue to hold
down until instructed to release in step 9.
4. Perform steps 5 through 8 in fairly rapid succession.
5. Turn the ignition switch to the ON position (as far as you can go without starting the
engine).
6. Turn the ignition switch to the OFF position.
7. Turn the ignition switch to the ON position.
8. Turn the ignition switch to the OFF position.
9. Release the power unlock button on the door panel. The vehicle will lock and unlock
the doors automatically.
10. Hold down the LOCK and UNLOCK buttons on the transmitter simultaneously until
the door locks and unlocks.
This step may take up to 30 seconds.
11. Repeat step 10 NOW for each additional transmitter (including any existing
transmitters).
12. Turn the ignition switch to the ON position in order to exit the transmitter programming
mode.
Hatter69 2010 LT1 Black #366
hatter69 is offline   Reply With Quote
Old 07-04-2010, 08:16 AM   #2
jshaf
Montani Semper Liberi
jshaf's Avatar
Drives: 2011 Black 2SS/RS w/ IOM stripes
or you can put one of your origional keys in the ignition and turn to the on position, then remove it, put your new unprogrammed key in the same ignition and turn it to the on position and wait to hear it beep and display "third key remembered" or some thing like that on the center display. that is how I programmed my ordered key. works just like the one that came with my car.
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint
jshaf is offline   Reply With Quote
Old 07-04-2010, 08:16 AM   #3
Danprh427
Drives: 2010 Camaro
1hr labor at a dealership comes out to 160 dollars so $50 isnt that bad if you really couldnt figure it out as a tech it take me like 10 min and i rather just do it for the person or their salesmen if i like them.
Danprh427 is offline   Reply With Quote
Old 08-21-2010, 07:14 PM   #4
GQ4Life
Drives: 2010 Camaro SS LS3
In case my dealer tries to charge too much where can I buy key fob online?
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 08-21-2010, 07:23 PM   #5
thiggin2
thiggin2's Avatar
Drives: 05/07 Chevy's
www.gmpartsdirect.com
thiggin2 is offline   Reply With Quote
Old 08-21-2010, 07:24 PM   #6
mike.nite
mike.nite's Avatar
Drives: 2011 2SS L99, 2010 LT RS
I would also like to know this. + where can I place a order for laser cutting online?
mike.nite is offline   Reply With Quote
Old 08-21-2010, 08:09 PM   #7
GQ4Life
Thank u guy. This has got to be the best forum. Sorry for writing in so many threads I was nervous & pissed.
Old 08-21-2010, 08:59 PM   #8
mojojojo7176
Drives: 2010 Camaro RJT 2SS RS
Ok so a little off topic...But I read somewhere that someone had bought a used key fob on ebay and was able to reprogram it. So my question is do all of our keys come cut the same ?
Hatter69 when you ordered the other key fob, did you do it from a dealership so it came cut already or what ?
Sorry for being confused on the matter.
mojojojo7176 is offline   Reply With Quote
Old 08-22-2010, 09:29 AM   #9
hatter69
I went to a Chevrolet Dealer ordered a new key. I was told that it had to be cut at the parts warehouse.
It came fre-cut.
Old 03-17-2011, 04:46 PM   #10
HondaEx
HondaEx's Avatar
Drives: 2010 2LT RS
Thanks, took me 30 seconds.
HondaEx is offline   Reply With Quote
Old 03-17-2011, 05:26 PM   #11
jshaf
jshaf's Avatar
your welcome dude, glad I could help
Old 08-26-2011, 08:35 PM   #12
gamarule
Drives: 2SS
Smile Quick question
I have lost the only key i had and contacted the dealer to get another one, they are charging me $43 for the key and $125 for programing, and on top i have to tow the car to them so thats another 75, can i use this method to program my key my self or do i have to have the original key to do it this way? i dont want to pay $200 for towing and programing,
Thanks a lot for your help in advanced!!
gamarule is offline   Reply With Quote
Old 10-15-2011, 07:47 AM   #13
Rogan
No Pain No Gain
Rogan's Avatar
Drives: Yellow 5th Gen 2SS RS
This worked. Took 10 secs ..maybe less.
A few web site have the keyfob for around $46. Got mine 3 days and did this last night. Got the key laser cut at a dealer for $20.
2010 2SS/RS/L99 - Headers/CAI/SWAYs/CoilOvers/Tune/Steel Braided Brake Lines/Frozen Slotted Rotors
Rogan is offline   Reply With Quote
Old 10-23-2011, 08:00 PM   #14
oswego16
2012 2LT Convertible
Drives: 2012 2LT RS Convert Blk/Blk/Inferno
OMG - so long story short my 2012 2LT RS Vert needed a new body control module. My key was fine. Wife takes the car today - my key in ignition, get's where she's going, get back grabs her key out of her purse - car won't start, 5 year old daughter crying "make it stop mommy, crowded shopping center, finally finds my keys drives home. Delicately, lets me know something is wrong with my car.
I knew immediately because had the same problem last year when the BCM went on our Tahoe.
Tried the first solution on this post - no avail.
The second - yup 10 seconds.
Thanks for the help.
oswego16 is offline   Reply With Quote
Remote Start System Installation – Need Assistance Railcar Camaro DIY & HOW-TO instructions & discussions 27 12-09-2013 04:51 PM
Key Fob Mod LED - My First Mod... Buhmblbe Camaro DIY & HOW-TO instructions & discussions 15 12-07-2010 05:23 PM
Remote Key Fob Design Fault GNVenom Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 54 06-01-2010 10:42 PM
Key fob reprogramable? Jason@JacFab 5th Gen Camaro SS LS LT General Discussions 9 05-18-2010 07:07 PM
Problem with Key Fob anyone? ffrcobra_65 5th Gen Camaro SS LS LT General Discussions 8 12-12-2009 01:45 PM
