09-20-2017, 04:26 PM | #1 |
Drives: 2016 Hyper Blue Metallic 2SS Join Date: Apr 2016
26 vs 28" Tires
Anyone out there running a 26 inch drag radial vs the 28 inch slick with an aftermarket converter without any traction issues? I'm currently running a Hoosier drag radial 315/35/17 (25.8 diameter) on a FBO/ E85, A8. Car leaves hard, and I don't have any traction issues right now, but I'm in the process of putting a converter in the car, and I was just wondering if anybody was running the shorter tire with a converter without any traction issues?
09-21-2017, 04:35 AM | #2 |
Drives: 2016 2SS Join Date: Jul 2016
With the converter you are going to have traction issues no matter what. I have to be very careful with the launch on my 28's. You really can't get any more tire back there than what I am running. If I actually try to use the converter as designed it just blows the tires off.
09-21-2017, 07:50 AM | #3 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
What kind if times are you running?
09-21-2017, 11:42 AM | #4 |
Drives: 1987 Buick Grand National Join Date: Mar 2016
Keep the 26 if you can. Only way to find out is to try it!
09-25-2017, 08:31 PM | #5 |
Going to go ahead and pull the trigger and do the 15'' rear conversion and stay on the 26'' slick/radial with more sidewall. Hopefully that works
11-16-2017, 12:22 PM | #6 |
Anyone guess what it's worth on a m6? I pulled the trigger on some rear wheels and thinking 26 but the 28s look way better
