09-13-2017, 07:40 PM | #1 |
Whats quicker in the 1/4 mile... a 26" or 28" tire
Question for you drag racers out there.
Car = 2016 Camaro SS A8 All things being equal with NO traction issues, what would be the quicker 1/4 mile... A 26" tire or a 28" tire? My assumption is the 26" tire would have a quicker 60' but slower trap speed vs the 28" tire. I'm only guessing as the shorter tire would lower the gear ratio. But which would run the quickest 1/4 mile?
09-13-2017, 09:48 PM | #2 |
Drives: 16' 2SS Join Date: Jul 2016
What trans? I think with on a stock car would be a 26" but on a power adder car I think the 28". There are different rear gear ratios from manual to auto.
09-13-2017, 10:08 PM | #3 | |
I'm talking N/A. Not sure it matters in this comparison. Take a stock Camaro A8..run it 5 times on 26" and 5 time on 28" What's quicker?
09-13-2017, 10:29 PM | #4 | |
Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
When the mods start...the pendulum swings.
09-14-2017, 06:40 AM | #5 |
Drives: 2016 2SS Join Date: Jul 2016
Not to disagree with Snowblind since I absolutely respect his experience and opinion. BUT, I will go with 26" the entire way. My findings running the 28's are that you have to execute that 4th shift into 5th regardless if you are trapping 114 mph or more. I am pretty sure we had a long discussion about this some time back. The 26" tire takes your rear gear from a 2.77 to a 2.97. When we take the accumulation of all the shifts and the time the car will stay in each gear and in the power band of this car, I see the 26" tire as the hands down winner. We know this car stock or with the stock heads and stock manifold is all about tq. It flops over around 5,700 so the more we can multiply tq the better off we are. I also think it will MPH better since it will execute the 4/5 shift sooner and be back in the power band in 5th sooner running out the back door.
09-14-2017, 07:04 AM | #6 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
I am assuming the 26" would also benefit the M6 cars by improving 60' times. What say you experts?
09-14-2017, 12:20 PM | #7 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Shorter tire will act like more gear. Car would be quicker on a shorter tire.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
09-14-2017, 12:48 PM | #8 |
Drives: 66 Chevelle SS Join Date: Mar 2013
The longer footprint of the larger diameter tire will provide better traction. Assuming your Nannies don't interfere.
66 Chevelle SS 396
91 octane Driver n/a 6.44@105.78 1/8th mile |
09-14-2017, 01:48 PM | #9 |
We all agree with that but the op stated traction was even or not a factor. Pure mechanical advantage.
09-14-2017, 01:57 PM | #10 |
True, but being stock and an A8, I leave at an idle. Don't need the bigger footprint yet.
09-14-2017, 05:45 PM | #11 |
Right now I'm on a 275/40-20. it's basically a 29" tire (28.82 to be exact). I can run 4th gear to the finish, I didn't need to shift into 5th. I trapped at 111. This was in Vegas, the DA was around 2900.
I'm thinking a 26"-27" setup will be better & quicker.
09-14-2017, 05:51 PM | #12 |
That makes sense. If you are running a stock height tire (26.83) or just near it. You will have to shift to 5th. Even with my ETr 28" (27.5) I still had to shift to 5th. Possibly on a real 28" tire bone stock you could hold 4th. I still think the shorter tire will be quicker.
09-14-2017, 06:30 PM | #13 | |
You're allowed to homie, nobody should be butt hurt over a different view....it doesn't make one person right and one person wrong, it's just an opinion.
I appreciate the openness of all your findings too. Quote:
Pray did state way back when that the 4-5 shift takes about .3 seconds to complete. I haven't looked into it that deeply but I will take his word for it. I have, however, experimented extensively with holding 4th and my math told me that I gained almost .04 in the 1/4 and gained 2-3 mph at the traps. In light of your more recent post, if you choose not to get bit by the speed bug and mod your car than look for a shorter tire, IMO you will see nominal differences between the 2 until your pour on the power anyways but good luck with whatever you choose. Nice car btw...the white ones are the fastest
09-14-2017, 07:33 PM | #14 | |
We need Bhilla to chime in. As far as I know he is the only one who actually has run both tires. IIRC, he went 11.2's on the 28's and then 10.9's on the 26's as the only change.
