09-22-2012, 09:57 AM | #1 |
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
Coding your GM locking gas cap DIY
*EDIT*
This cap is now replaced with GM part # 23159210 The price has increased to around $50 online. So There are several threads about this gas cap and having it coded by a dealer for $50, or having a locksmith do it. If you dont have extra cash or your key code you can follow my instructions and get it done in less than 10 minutes. For those of you that do not know, this cap works with your existing side cut key. About $22 from dealer, $15 or less online GM part # 22790846 AC Delco # GT344 The tumblers are listed as 1L, 1R, 2L, 2R, etc. these are left or right specific. One side of the lock cyinder has 2 keyhole slots and one has 3. The side with the 3 keyhole slots is the LEFT side. There are 2 tumblers per side, the 3rd one on the left side is for the brass retainer clip. Grab one tumbler that has a L in it and insert it into the first keyhole slot. Hold the tumbler centered in cylinder and insert your key all the way. Slide the sleeve (tab end first) over the cylinder. If it stops at the tumbler it is the wrong one. (pic below) If correct it should slide all the way up and rotate 90 degrees. Once first position is correct leave it in and repeat for other left tumbler. Then find both right side tumblers the same way. Now carefully remove each tumbler and remember its location. (the 5,6,7,8 below is the order of the cut positions if you get the code from the dealer) Insert 2 springs (I did right side 1st) Insert tumblers. Repeat for left side. Insert your key, and slide over the cylinder sleeve. Make sure it rotates smoothly. If everything is good insert the last spring and the brass keeper till it clicks in place. Check for full operation one last time. Once you install the cylinder into the cap it will not come out. Align the 3 tabs in the cap, and the 3 grooves of the cylinder. Press together, till it clicks. You may have to rotate the handle, while holding the white part of the cap. Make sure you get those 2 tips on the end of the cylinder to line up. Insert key, and test. Thats all, its pretty easy. Last edited by GVA 45TH 2SS; 10-08-2013 at 07:00 PM. |
09-22-2012, 10:29 AM | #2 |
Drives: 2SS/RS Join Date: Sep 2008
You're pics aren't working for me.
09-22-2012, 10:39 AM | #3 |
KNGTFALL
They should be up now.
09-22-2012, 12:54 PM | #4 |
Drives: 45th 2SS M6 Join Date: Oct 2011
Nice Writeup, great info!
09-22-2012, 05:39 PM | #5 |
Drives: CGM 2SS/RS, 1987 & 2014 Silverado Join Date: Oct 2010
When I saw all the parts that come in the bags I was worried, but getting them togther was really easy. Good job with the pictures. I have had mine for over a year and this keeps me from leaving the keys in the car when I fuel up.
09-22-2012, 07:16 PM | #6 |
KNGTFALL
Thanks,
I was worried about trying it myself, but I ordered it anyway. When I figured it out, well I decided I had to show others how easy it can be. The hardest thing was holding the tumblers in place while adding more. |
09-22-2012, 08:46 PM | #7 |
Drives: Black 2012 2LT Join Date: Apr 2012
Nice.
09-24-2012, 01:15 PM | #8 |
Drives: 2011 Camaro 1SS Join Date: Apr 2012
Great write up. I'm planning on doing this real soon.
09-25-2012, 12:12 AM | #9 |
sweet! too bad i already have the defenderworks cover
11-16-2012, 11:42 PM | #10 |
Drives: '13 ZL1 CRT #702; '05 Hemi Ram Join Date: Oct 2012
Thanks for the pics. Very helpful!
11-17-2012, 02:53 AM | #11 |
Drives: 2010 Camaro 2SS RS Join Date: Nov 2011
wow never knew this existed from GM... will purchase soon!
11-17-2012, 12:21 PM | #12 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
I just did this not 10 minutes ago. Easy peasy. And it DOES fit 2010s for anyone wondering like I was. (book doesn't show it fitting 2010 for some reason)
Just a couple of notes. The pin holding it onto the cap can be a mofo. It's plastic and will pop off, but you may mangle it if you're not careful. I almost did. Also, obviously since it has more moving parts, it's heavier than the original cap by far, so be careful not to let it drop when you're removing the key so it doesn't clunk the quarter panel. More potential for damage.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
11-17-2012, 04:30 PM | #13 |
KNGTFALL
[QUOTE=el ess X;5818213]
Just a couple of notes. The pin holding it onto the cap can be a mofo. It's plastic and will pop off, but you may mangle it if you're not careful. I almost did. QUOTE] Yeah I didn't talk about removing the strap to the door. Your on your own there |
11-29-2012, 11:49 PM | #14 |
Drives: ZL1, 2012 3500 Duramax Dually 4x4 Join Date: Jan 2010
Thank you!
