02-02-2024, 08:43 AM | #1 |
Drives: Camaro LT 2012 Join Date: Jan 2020
HELP: "Low Oil Pressure. Turn Off Engine" at RPM X4000-5000
Guys,
Here is the deal : When driving above 90MPH (RPM X4000-5000) I get notice on the screen "Low Oil Pressure. Turn Off Engine" When it's less then RPM X4000-5000 the "notice" turn off and all is fine. Your ideas? Thanks for help! Last edited by BoloYang; 02-02-2024 at 11:17 AM. |
02-02-2024, 02:45 PM | #2 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Is your oil pressure dropping when increasing engine rpm?
02-02-2024, 02:48 PM | #3 |
Have you checked your oil level? Sounds to me like the oil pump is sucking the pan dry at those elevated RPMs before the oil can return to the sump, which would be a symptom of low oil levels.
02-02-2024, 03:06 PM | #4 |
02-02-2024, 03:08 PM | #5 |
02-02-2024, 03:28 PM | #6 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
There could be an issue with the oil pump. Maybe there is a tooth broke in the gear. Or maybe your pick up tube is blocked.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
02-02-2024, 06:26 PM | #7 | |
Drives: 2011 Camaro SS LS3 Join Date: Jan 2022
I wouldn't push that car too hard because the engine is giving you signs that it's about to go bye-bye. Have a mechanic check your engine ASAP! Also, search this forum for previous owners who had the infamous "oil pump" issue with 2010 - 12 Camaros. Good luck! |
02-02-2024, 07:03 PM | #8 | |
Thanks for tip! I got 136K on mileage with 3.6-liter V6 engine -- the infamous "oil pump" issues happend to people with 10-20K mileage 2010 camaros. Already looked into it.
02-02-2024, 08:03 PM | #9 | |
Drives: ABM #93 Join Date: Oct 2018
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
02-02-2024, 08:15 PM | #10 |
First should be to put a mechanical gauge on it to check pressures.
02-02-2024, 08:19 PM | #11 |
02-02-2024, 08:26 PM | #12 |
Ok, mine grenaded at 52k miles on my LS3 which exceeded the bumper 2 bumper warranty and the dealer (in Los Angeles, CA where I lived at the time) tried to deny me, and after getting GM involved, the PowerTrain warranty was invoked. I believe that you have an internal engine issue and it will cost you $$$ out of pocket if you don't have an aftermarket warranty that will cover it. Again, good luck!
02-02-2024, 08:37 PM | #13 |
I definitely agree, as said above I would manually check the pressures and then evaluate from there. Could be as simple as a bad sending unit or as catastrophic as impending engine failure. Either way definitely not something you want to let slide.
02-03-2024, 01:19 PM | #14 |
Guys,
Thanks again for replys - on monday i have manually checking the pressures - will keep update. |
