Old 03-16-2024, 05:10 PM   #1
302crossram
302crossram's Avatar
Drives: 2023 Sharkskin 2SS
Does 2024 Silverado 2500... 6.6L. have DoD ?
all 8 all the time or afm bullsh*t ?
Old 03-17-2024, 10:37 AM   #2
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
No AFM on the L8T. I really like my ‘22 a lot. It does use some oil though FYI.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 03-18-2024, 02:29 PM   #3
Realist
Realist's Avatar
Drives: No Camaro :(
How much oil in how many miles? What MPG are you averaging? Thanks!
Realist is offline   Reply With Quote
Old 03-18-2024, 05:11 PM   #4
Aqua Blue RS/SS
Drives: ABM #93
I can get 16+ if I drive it right but it’s loaded up fairly heavy with tools most of the time. Mind you as a 2022 mine has the 6l90 and not the 10 speed ally. We’ve got a few of the 10 speed trucks at work but I’m not sure how the mileage compares. It’ll sometimes use 1.5-2 qts in 5000 miles. I don’t run it to the change light. It didn’t start using it like that till about 30-35000 or so. It’s just over 50K now. I have a catch can on it now since about 48,000 miles (last oil change) and it’s about 3/4 full) I’ve been checking it every couple hundred miles to see how long it takes to fill up.
Old 03-21-2024, 09:53 AM   #5
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
This amount of oil usage has been considered as acceptable in the past. Oil usage, although undesirable, exists for some engines. If you follow the common standard for oil changes (which would be to service and change oil within 4,000 miles), you should never run into a problem with oil. I always follow this standard with all of my cars, and I don't add oil to any of them.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
lbls1 is offline   Reply With Quote
Old 03-22-2024, 03:56 PM   #6
Aqua Blue RS/SS
Drives: ABM #93
Yes, GM says this amount is totally normal in the LT engines… It’s well documented that the issue is in the ring packages they are using on the current engines. Guess it’s ok after all to burn all that oil with emissions standards the way they are… I don’t think the oems are going by the common standard of 4,000 miles. If you run it till the service light it’ll go 7-8,000 miles. 5,000 is plenty for me.
