12-05-2022, 02:38 PM | #1 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
Cruise control 1978 Camaro
Could someone give me advice or draw a wiring diagram for the cruise control hoses on a 1978 Camaro?
I've been struggling with it for several years - so not intensively. More like when I'm in the mood and feel like it, but I can't move it. They took it apart for me at the service center and it never worked again. The components should all be there.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
12-05-2022, 02:48 PM | #2 |
It looks like Helms has the service manual available. It "probably" is in there.
12-05-2022, 03:41 PM | #3 |
I have a photocopy of the workshop manual but it is illegible.
I am mainly concerned with connecting the vacuum bellow on carb and the hoses on the module where they go.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. Last edited by George-CZ; 12-05-2022 at 04:19 PM. |
