TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 10-20-2018, 11:51 PM   #1
gsxrturbo
Drives: 2010 ss
Qa1 2 way adjustable shocks
So how well do they work for drag racings?How much front end lift?if any.I don't know if they will work for our cars.6 speed manual and 845 rwhp.thanks guys
gsxrturbo is offline   Reply With Quote
Old 10-20-2018, 11:52 PM   #2
gsxrturbo
Drives: 2010 ss
For the front
Old 10-25-2018, 04:54 AM   #3
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
they would be a decent set. they need to be done front and back to see the full benefit of doable adjustable coilovers for a drag application.
menscer shocks are hands down the best shocks on the market for our cars right now.
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
ttshovel is offline   Reply With Quote
Old 10-26-2018, 07:14 AM   #4
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
If you're going to buy a shock and or strut, buy the best.
BFASTNOTLAST is offline   Reply With Quote
Old 10-26-2018, 07:16 AM   #5
BFASTNOTLAST
Drives: 2012 SS LS3
Traction package.
Old 10-28-2018, 07:52 PM   #6
stratman2SSRS
stratman2SSRS's Avatar
Drives: Lingenfelter Camaro
^^^ You had to relocate the lower mounting hole??
stratman2SSRS is offline   Reply With Quote
Old 10-29-2018, 08:12 AM   #7
BFASTNOTLAST
Drives: 2012 SS LS3
Otherwise you cant adjust the rebound as the knob is buried in the LCA.
