Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 08-12-2018, 07:47 PM   #1
U LUZE
U LUZE's Avatar
Drives: 2012 ZL1
Slow 60' times
Hey guys. My 60s have been bad. Mods in sig. I have 17" Mickey ET Street Rs. I'm running 1.8 60s with a rare 1.7 in there. I've tried a drag alignment and running from 16psi to 20psi with no dramatic improvements. I'm leaving from idle. I spin out of the hole every time. Track prep not an issue. Any ideas?
~ 2012 ZL1 - DynaTech 1 7/8" Headers - ID 1050 Injectors - E85 - DSX Aux Pump -
22.5% Crank Pulley - Roto-Fab CAI w/ Big Gulp-
CJ/Jannetty Tuned ~ PB ET 10.54
U LUZE is offline   Reply With Quote
Old 08-13-2018, 04:17 AM   #2
bayarea408
bayarea408's Avatar
Drives: T
auto or stick?
bayarea408 is offline   Reply With Quote
Old 08-13-2018, 07:13 AM   #3
U LUZE
U LUZE's Avatar
Drives: 2012 ZL1
Auto. I hold down the t/c button to turn off the nannies. Even tried it in race mode 5 which seems to help a little.
Old 08-13-2018, 07:50 AM   #4
KB85
Drives: Camaro
what TC you running?
KB85 is offline   Reply With Quote
Old 08-13-2018, 08:06 AM   #5
U LUZE
U LUZE's Avatar
Drives: 2012 ZL1
Stock TC.
Old 08-13-2018, 08:18 AM   #6
Nb1081
Drives: 10 2ss/rs
Are you preloading the suspension or leaving from idle
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
Nb1081 is offline   Reply With Quote
Old 08-13-2018, 09:22 AM   #7
U LUZE
U LUZE's Avatar
Drives: 2012 ZL1
Leaving from idle. This is the way I've always left. Earlier this year I was high 1.6s and low 1.7s. Maybe this is 'normal' for how I'm launching, but it seems high. I am spinning past the 60' which is obviously a big part of my issues.
Old 08-13-2018, 11:26 AM   #8
Nb1081
Drives: 10 2ss/rs
Put your foot on the brake and hold gas a lil almost to point of burnout while your staged go on 3rd yellow (doubt your running pro tree) and dont go to floor roll into it a lil and with lower tire pressure you can maybe get the 20 inch tire to wrinkle a lil to give more traction area when you come off the line
Practice the foot brake at red lights you dont need to speed to practice a launch
Old 08-13-2018, 12:10 PM   #9
swiftkart
swiftkart's Avatar
Drives: 2010 SS/RS LS3 M6
He said he has a 17"setup.
swiftkart is offline   Reply With Quote
Old 08-13-2018, 12:36 PM   #10
Nb1081
Drives: 10 2ss/rs
Ok my bad so he can get the tire to squart and wrinkle a lil more then even better for his wants by the tire squating and wrinkling it absorbs some of the initial hit and helping transfer the power down to the ground
Old 08-13-2018, 12:45 PM   #11
U LUZE
U LUZE's Avatar
Drives: 2012 ZL1
Thanks guys.... Just trying to figure this out. I get the concepts. I started off at 20 psi and kept dropping it down to 16 eventually. It just doesn't seem to improve it drastically. I think I should be cutting low 1.6 60s with the power I have which is what makes this frustrating. I do stab it from idle on my launch. I could probably try rolling into it, but should I really have to do that with the Mickeys?
Old 08-13-2018, 01:46 PM   #12
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
Make sure you’re doing a nice smoky burnout to get those tires warm. I was doing too small of burnouts and the tires wouldn’t get warm enough to hook good
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 08-13-2018, 02:09 PM   #13
U LUZE
U LUZE's Avatar
Drives: 2012 ZL1
When I had my Nittos I had to do a massive burnout to get them sticky. The bigger the burnout I do with the Mickeys the greasier/slicker they seem to get. They seem to just like to be 'glazed'. Not sure if that is just me?
Old 08-13-2018, 02:22 PM   #14
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
ran the et streets first time this weekend my smoky burnouts at 18psi were the best
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
Bretts is offline   Reply With Quote
