03-28-2024, 01:03 PM | #1 |
Drives: 2023 ZL1 - Modified All Bolt On's Join Date: Dec 2022
any reason NOT to use recommended oil...
So, I have an open "Free oil" change with a GM dealer from when I bought my car. I've not used it, and don't plan to because I don't want my car in shop unless absolutely necessary. With that being said, I changed my own oil at 500 miles and ready to change it again at 2700 miles. Last time I used Mobil 1 Supercar Full Synthetic 0W-40 and a ACDelco PF64 filter. Would there be any reason to select a different oil vs just stick with what I've been using?
Thanks
2023 ZL1 A10 - CSP 2" Long Tube Headers by Stainless Works | Gesi G-Sport High Flow CATs | Stainless Works Legend NPP Axle Back | Roto-Fab Big Gulp | Kong NM103mm | Kong X-Port/Polish w/Griptech 2.3" Upper | Granatelli Malevolent Coil Packs | Granatelli 0 Ohm Plug Wires | Katech Valve Covers w/Coil Relocation | FI Interchillers Blower Spacer Plates | Mighty Mouse Mild | JMS Flex Fuel Booster | DSX Flex Fuel Kit | DSX Billet Lid | DMS 2gal Fender Tank | NT555R2's 305/285 | AEM w/b AFR | Banks iDash Data Monster | HPTuners MPVi3 Module and Licenses (ECU & CCM) | Remote Tuned by Ted at JRE
03-28-2024, 01:07 PM | #2 |
No reason unless you’re gonna track your car or go with the recommendations after being highly modified
03-28-2024, 01:11 PM | #3 |
Sooo, no tacking. But any harm in going 5W50 anyway? I don't drive my car when the are less than 40°!
03-28-2024, 01:18 PM | #4 |
The lighter weight oils will get into your internals faster, if you’re not abusing your engine stick with the lighter weight, like 5-30 if 0-40 gives you concern
03-28-2024, 01:19 PM | #5 |
If you’re doing your oil change then go with the factory suggested brand and weight. I do my oil changes and use Lucas 5w30 and either a Mobil 1 or Napa Gold filter. That’s just me though.
03-28-2024, 01:20 PM | #6 | |
03-28-2024, 01:26 PM | #7 |
03-28-2024, 02:32 PM | #8 |
Thank you Al Oppenheiser!
Send samples to Blackstone-labs and pay the extra for the TBN ($45). Gives your grandkids a great documented provenance on the original survivor numbers matching engine
03-28-2024, 02:49 PM | #9 |
Sarcasm loading --------
Once I put the higher viscocity oil in for a track day that is when my oil pump started to fail.
I ran about 3 morning sessions and had to leave due to the tires becoming shredded on the outside face. I drove home then changed the oil the next day but the damage was already done. Then there is chevy to worry about. The chevy field technician said that the oil filter was installed "incorrectly" and i had the wrong oil in it. The pump failed, and when pressed Chevy said that they will only pay 30% of dealer invoice for repair because I tracked the car, installed the oil filter wrong and used the wrong oil; which is BS. Proceed at your own risk.
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
03-28-2024, 02:57 PM | #10 | |
03-28-2024, 03:28 PM | #11 |
That's what I was asking ! So just stick to recommended 0W40 !!! I'm good with that !!!
03-28-2024, 03:50 PM | #12 |
Yes! Unless you are going to track the car or highly, modify your engine and use the recommended oil, I thought I said that already. I thought my first time suggestion would set in.
03-28-2024, 03:56 PM | #13 |
Sorry, I am old and impatient
03-28-2024, 03:58 PM | #14 |
You can’t teach…….
