Old 01-29-2024, 02:26 PM   #1
VT Camaro
Drives: 18 Camaro SS
Four cylinder mode
Hello Everyone,
I'm new to the forum and fairly new to the Gen6 Camaro. I have question regarding the four cylinder mode. It appears that the car never goes into this mode, and stays on V8 mode at all times. I had a 2014 Corvette and the symbol would change between V4 and V8 modes, and could also feel it most of the time when this would happen. While I am quite happy that it stays in V8 mode all the time, I am also very curious why? Any thoughts? I have tried all four drive modes, and this has made no difference.
The Camaro is a 2018 SS automatic and currently has about 9K miles on it. I am the second owner.
Thanks!
VT Camaro is offline   Reply With Quote
Old 01-29-2024, 02:29 PM   #2
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
If it’s been tuned then AFM was probably turned off.
I believe Track mode keeps it in v8 mode but the other modes switch (might be wrong here)
You’ve been checking the trip or mpg screen watching the v8 on the page, when it switches to v4 it’s a green tint over it
2022 2SS 1LE - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
Bumbleboy92 is online now   Reply With Quote
Old 01-29-2024, 02:45 PM   #3
VT Camaro
Yes, it never goes green just stays gray. Plus I don't feel the subtle jolt either when it switches from one to the other.
If it has been tuned, does this mean it can't be tuned again? This was the main reason I was asking this question. I want to be able to have the transmission tuned in the near future.
Thanks!
Old 01-29-2024, 09:02 PM   #4
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
First, look at the OBD port for a plug-in module.
Second, staying in V8 mode isn't a bad thing. There are a lot of people with bent lifters associated with the V4 mode.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair.
Daily Driver mileage update: 22k mi. @ April 2024
New Engine @ 22,600
Old 01-29-2024, 10:02 PM   #5
Bumbleboy92
Long hauler
My car was one, 10k miles and the lifter failed
To OP, if it’s not tuned and nothing in the OBD then something’s up with the car. It switches to v4 on cruising and on slight acceleration. It’ll swap to v8 at any opportunity to
2016 1LT v6
- Totaled
Happiness: Infinite
Old 01-30-2024, 07:17 AM   #6
VT Camaro
I have the Range device on my truck for this purpose, but there is nothing in plugged into the OBD port on the Camaro. Guess that I can only assume that the previous owner had it tuned. I am pleased that it doesn't go into the V4 mode. I just hope this doesn't create a problem for future tuning?
Thanks for replies, this has confirmed my suspicions.
Old 01-30-2024, 07:50 PM   #7
jericho_17
Drives: 2017 Camaro 1LT
I did Trifecta tune for that purpouse, but in the case of Trifecta V4 can be activated in tour mode but not anymore in sports mode, probably you have a different tune.
jericho_17 is offline   Reply With Quote
Old 01-30-2024, 09:00 PM   #8
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Thanks!
Hopefully the previous tuner didn’t lock the tune so that your tuner can update the ECU and TCU for you. You should be able to run a “difference” comparison between your current tune and a stock tune with HP Tuners software. That might help you understand what’s been changed. It’s possible that the previous owner had the TCU unlocked and tuned too.
