01-01-2014, 04:27 PM | #1 |
Montani Semper Liberi
Drives: 2011 Black 2SS/RS w/ IOM stripes Join Date: Feb 2010
have a question about factory amp replacement
do I have to get an amp install kit when I buy the aftermarket amp? I am guessing that the OEM amp has a power line, fuse etc already running to the battery. am I correct? I have the car tucked away and haven't had a chance to look under the carpet in the trunk yet, just bought her in nov and put her in storage shortly afterwards. wasn't sure if I needed to buy a kit along with the fark, rca's, etc
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint |
01-01-2014, 05:42 PM | #2 |
Drives: Black 2011 2SS/RS / Black 2013 ZL1 Join Date: Feb 2012
You'll need the cables for power and ground and a fuse. Nothing from the stock amp to power your aftermarket amp.
01-01-2014, 08:23 PM | #3 |
what should I buy? 4awg and specific fuse type? recommendations?
01-01-2014, 08:33 PM | #4 |
having FUN now 13.66@101
I had a friend of mine help me with my AMP replacement.
Here is where we bought my stuff. http://www.halfpricecaraudio.com/ http://www.parts-express.com/ ********.com Here are a few photos too. Hope this helps. I am looking for my email receipts of items I bought too.
01-01-2014, 08:47 PM | #5 |
Drives: 2010 Camaro 2SS/RS RJT, 6speed Join Date: May 2011
Yes, you need an install kit for power and ground to battery. FARK does not run power to aftermarket amps.
2010 Camaro 2SS/RS, LS3 - 6 speed. Mods, Magnaflow exhaust with resonator delete. ******** 12" stealth box subwoofer kit, Kicker 400 mono amp, JL XD 400/4 amp.
01-01-2014, 09:23 PM | #6 |
Drives: 2012 2SS Join Date: Aug 2013
Fark kit makes Install easy, no wires to splice.
01-01-2014, 09:32 PM | #7 | |
01-01-2014, 10:07 PM | #8 |
I would use at least 4 gauge wire.
01-01-2014, 10:45 PM | #9 |
did a little search and found out the kit I used in my last car was Metra TC5KIT-4, 110 bucks on best buy, need a less expensive alternative that is OFC
*************found it for 29 bucks on ebay :o) crazy Best buy mark up****
01-02-2014, 01:36 AM | #10 |
Take a look online. There's a lot of less expensive kits online like at sonic electronix or amazon.
Kits are much cheaper there
01-02-2014, 06:31 PM | #11 |
01-02-2014, 07:41 PM | #12 |
Drives: Dark Knight Join Date: Sep 2012
I would let the installer cut your wires and put you kit together during installation. If you buy a kit your going to pay for stuff that wont be used. They only need a couple of feet of power and ground cable, they dont need speaker wire and because the amp in in the trunk with the fark you only need 3 ft RCA cables. The kits dont come with cables that short. Save some money and let the installer peice it together based on what you really need
01-02-2014, 07:59 PM | #13 | |
01-02-2014, 08:15 PM | #14 |
Dont forget if you plan on running a sub you need 3 sets of RCAs
