11-27-2013, 02:08 PM | #1 |
Track > 1/4 Mile
Proven Cooling Methods
So since the holiday season is just around the corner, I'm thinking my next mod MAY be cooling (already have intake, headers, tune, TB). Before I up the power with a pulley I'd like to address possible cooling issues. I already have the D3 tank, and I've heard that a larger HEX is only good if you do something about the intercooler core itself (only as good as the weakest link). My question is, what are proven cooling methods? I'm also considering meth as well.
For me personally my end goal is probably around 600 rwhp.
11-27-2013, 02:14 PM | #2 |
Drives: Widebody 2013 Mustang GT Join Date: Feb 2012
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
Water/Meth for sure. I think that's your next step for sure so that you can see an improvement in power but in IAT's.
11-28-2013, 01:58 AM | #3 |
Drives: 2017 ZL1 A10 Join Date: Aug 2009
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir Glassskinz rear window valance . 2012 ZL1 A6 (SOLD) Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC. Alky Control, FIICHILLER. |
11-28-2013, 06:47 AM | #4 | |
Drives: 2014 ZL1m6 red hot #569 Join Date: Dec 2009
11-28-2013, 06:51 AM | #5 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
This one is the best if you go that route,
http://activeinterchiller.com/5373.html
2017 Grand Sport, Borla X Pipe.....Enough Said
11-28-2013, 09:35 PM | #6 |
Track > 1/4 Mile
I had the RX chiller on my other Camaro and it was the biggest POS I have ever seen, I had leaks and other issues.. I know it was a (poor) copy of other chiller systems and Tracy @ RX is a joke. BUT still that has basically ruined the chiller or any similar system for me.
11-29-2013, 08:39 AM | #7 |
Drives: Camaro ZL1 Join Date: May 2012
Meth is a proven method. BUT (and I am ready for everyone to disagree) if you run meth through a single nozzle pre-blower, you run the risk of uneven atomization between the cylinders. If you are running more timing, and a cylinder isnt getting meth, you have a problem. If i was going the meth route, i would get a direct port setup just like they do for nitrous.
2012 A6 Coupe 630RWHP 10.93@125
Mods: ID850 Injectors; D3PE HX, Reservoir & Atmospheric Catch-Can; LPE 2.55 Upper & 9.1 Lower Pulleys w/ ATI Damper; LPE Idler Pulley Relocation Bracket; "Green" Serp. Belt; Cat delete;ADM Exhaust Override; Magnaflow X-Pipe Muffler (in addition to stock mufflers); Cold Air Inductions CAI; 160 thermostat; LS9 Isolator; Port/polish snout and intake runners; LPE GT9 camshaft with dual springs and titanium retainers; Kenne Bell BAP, Install and Engine Tune by Serious Hp; Fab work by D3 Performance Engineering; Trans Tune by Keith; Coming Soon: Flex Fuel Conversion. |
11-29-2013, 03:56 PM | #8 | |
Drives: '12 ZL1 #1609 Join Date: Feb 2010
Life is too short to drive cars that suck.
My build Thread |
11-29-2013, 05:14 PM | #9 | |
Drives: none Join Date: Aug 2011
11-29-2013, 05:27 PM | #10 | |
11-30-2013, 11:05 PM | #11 |
@white 2SS - I also run the D3PE HX - IAT2s with my mods were pushing 200* after a pull on the dyno during the summer (figure starting temps around 100*). After the swap, temps climbed to about 130*. The intercooler within the supercharger is indeed the limiting factor. Its not very big.
12-01-2013, 09:53 AM | #12 | |
Track > 1/4 Mile
12-01-2013, 10:40 AM | #13 | |
12-01-2013, 01:59 PM | #14 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
I seem to have very good cooling right now. Haven't had any really high temps to test it though. I have about 3.5 gallons in the trunk and route water from supercharger directly to Ron Davis intercooler in grill then back to reservoir in trunk.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
