Old 11-29-2012, 02:21 PM   #1
HubStep
HubStep's Avatar
Drives: 2010 Victory Red 2SS
At what point is a larger alternator necessary?
Wondering if anyone has run into the "limit" yet and what that was.
I'm running:
-a ton of RGB LEDs, with more on the way.
-additional xenon projector fogs.
-(future) 2x 15" subs + speaker / amplifier upgrades + 2x 8" subs.
-And lots of other stuff I'm cooking up.
I know I'm well inside the "safe zone" for now, but I haven't heard of anyone upgrading the alternator on here yet so it must not be much of an issue?
Thanks in advance for any advice you have! (Btw mine's the V8, if there's a difference).
HubStep is offline   Reply With Quote
Old 11-29-2012, 03:40 PM   #2
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
the lights wont matter. depending on how big the amp is, how loud you have it, you may have an issue, but doubt it.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 11-29-2012, 03:47 PM   #3
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
the factory alternator is 150amps, so you should be able to figure out how much you are taxing the alternator. I doubt more than 65-70%.
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
Old 11-29-2012, 03:52 PM   #4
Mr. iNCREDIBLE
Mr. iNCREDIBLE's Avatar
Drives: 2012 2SS/RS Convertible
alternator calculator:
http://www.highoutputalternator.com/...calculator.htm
I'm only responsible for what I say, not for what you fail to understand.
Mr. iNCREDIBLE is offline   Reply With Quote
Old 11-29-2012, 04:17 PM   #5
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS For Sale
Leds draw very little, and think your new fogs wouldnt be that much over the stock ones.
vroomapunk is offline   Reply With Quote
Old 11-29-2012, 05:30 PM   #6
BlackMamba88
BlackMamba88's Avatar
Drives: 2010 Challenger 345 R/T
You'll be alright.
With that sound System you want you should need a stronger battery like a Kinetik KHC2000.
Led Lights draw less power.
BlackMamba88 is offline   Reply With Quote
Old 11-30-2012, 01:37 PM   #7
HubStep
HubStep's Avatar
Great! Thanks for the advice. Has anyone ever done a dual-battery setup on here?
Old 12-02-2012, 01:55 AM   #8
joshylife
lift.eat.money.sleep.
joshylife's Avatar
Drives: 2013 2SS 1LE
Pfft ya man your draw is a lot higher that your output. What the rms of the subs alone? Is get that HO alt asap. You'd probly notice an increase in audio quality too.
joshylife is offline   Reply With Quote
Old 12-02-2012, 04:18 AM   #9
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
When you can see lights dimming and the voltage meter dipping, time for a HO alternator. Or do the math. If lights aren't dimming you should be good though. Best thing is when you fire up the 15s make sure to wire the amp with the proper gauge wire. I used 1/0 to a distribution block and 4GA to each amp. Very short runs. Make sure the ground is same gauge as power supply.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 12-02-2012, 11:12 AM   #10
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
Run a good quality capacitor on your amp and it won't tax the car's electrical system as much,
No dog in this fight anymore.
5th Gen owner 2009-2016.
two_wheel_mayhem is offline   Reply With Quote
Old 12-02-2012, 12:06 PM   #11
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
150 amps is huge. When I put twin 900 watt amps in my 1970 Chev 4x4, they had me upgrade to a 105 amp and I was good.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 12-02-2012, 03:52 PM   #12
CWI
CWI's Avatar
I am running 2 12" subs with 1100 watts RMS to each and I have no problem while the car is running.
