Old 09-21-2017, 07:20 AM   #1
Torquem
Bannable
Torquem's Avatar
Drives: 2017 Camaro ZL1
So... 19x12 will work.... but 20x12 will not?
I'm curious if someone has a cut or pictures showing why this is the case. I'd like to see what changes going from a 19x12 to a 20x12 inch wheel that prevents it from being run. Thanks for any help!
Torquem is offline   Reply With Quote
Old 09-21-2017, 08:13 AM   #2
JeromeS13
Drives: 2017 1SS/1LE
What's the source of this information?
Old 09-21-2017, 08:55 AM   #3
LibertyHill
LibertyHill's Avatar
Drives: 16 2SS 6MT NPP MRC / 15 K1300S
Originally Posted by jwdominick View Post
I run a 19x11 and a 18x20 forgestar f14
BADASS!!
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC
LibertyHill is offline   Reply With Quote
Old 09-21-2017, 10:55 AM   #4
Torquem
Bannable
Torquem's Avatar
Custom wheel manufacturers.
Old 09-21-2017, 11:50 AM   #5
JeromeS13
Given the same offset, that doesn't make any sense. The only limitation at that point would be the tire size...
Old 09-21-2017, 01:30 PM   #6
Torquem
Bannable
Torquem's Avatar
Exactly. So that's why I'm asking the question
Old 09-21-2017, 01:41 PM   #7
FlowForm_Wheels
FlowForm_Wheels's Avatar
Drives: Turbo 4, SC V8 and Twin Turbo V8
Not that I'm aware of any similar issues, but for example a Cayman GT4 if you run a 19" wheel the maximum rear wheel size is 10.5" due to the toe link on the rear, but if you were to run a 20" wheel, that barrel size gives enough clearance to the toe link to use a 20x11" wide wheel.
I'm not aware of any issue like this on the Camaro though... Anyone who says a 12" wide wheel actually 'fits' on this car is bending the truth though. Widest recommendation we give is a 11" wide wheel on this car. Any size larger than 11" without modifications done to the car to accommodate, will cause the wheels to poke outside the fenders.
FlowForm_Wheels is offline   Reply With Quote
Old 09-21-2017, 03:18 PM   #8
Torquem
Bannable
Torquem's Avatar
The Zl1 1LE runs 19x12 and it the same fenders, no?
Old 09-21-2017, 04:11 PM   #9
FlowForm_Wheels
We haven't yet seen a local ZL1 1LE to laser 3D Scan yet (yes we 3D scan every car so that we can determine our fitment instead of taking measurements by the old school way), so I can't compare and contrast with the info I have, but I'm sure a combination of things allows GM to run a wider wheel. Even an offset coilover system that gives more clearance for the wheel could give us an extra inch of room, it just depends on all the variables, not just the fenders.
If anyone local to San Diego, CA wants to allow us to scan their car, we'd get to the bottom of it and verify the differences.
Old 09-21-2017, 04:53 PM   #10
Torquem
Bannable
Torquem's Avatar
The z28 wheels are 19x12 as well, aren't they?
Old 09-21-2017, 07:40 PM   #11
seddon
seddon's Avatar
Drives: 2017 ZL1
You need to have the right offset and back spacing. You need the right wheel company maybe hre, adv1, or edc
Elite Design Concepts NY5THGEN2017 ZL1 Garnet Red/M6/// IG @Crazl1
seddon is offline   Reply With Quote
Old 09-21-2017, 08:11 PM   #12
PK Auto Design
PK Auto Design's Avatar
Drives: 2017 Chevrolet SS 1LE
19x12 and 20x12 can be done
I have done multiple setups using a 19x11 to 12" rear
This can be done on a 20" also.
PK Auto Design is offline   Reply With Quote
Old 09-22-2017, 11:40 AM   #13
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
I can't think of anything that would cause that. The extra half inch radius only makes for a bit more air space in the middle of the wheel & tire. Thats not a problem for anything. Sure, the barrel is sitting out a little farther from the rim but anything that it would be hitting would get the tire on a 19" rim.
Did the place that told you this happen to be out of 20 x 12 wheels and/or extra sets of 19x12's?
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 09-27-2017, 01:52 AM   #14
RideZX6R
Probably tired right now
RideZX6R's Avatar
Drives: 1Lap1LE | EV6 FE | 18 F150
the main reason is DSSV shocks (like on the ZL1 1LE) are much narrower than the wider Mag ride shocks.
-Seven
'17 SS 1LE - 1LAP 1LE (Now with more 427!)
'18 F150 Platinum Powerstroke diesel
'22 Kia EV6 First Edition
'18 RS3 (1 of 2) Cumulus Blue
'24 911 T (ordered)
Formers...
'19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor
RideZX6R is offline   Reply With Quote
