Roto-Fab
Old 08-08-2022, 12:17 PM   #1
camarohead
camarohead's Avatar
Drives: 2010 ss rs ls3 red-white rallys
2010 camaro suspension upgrade
Wanting to get the bmr 1 inch drop springs and also some other things to upgrade the suspension.. is there a package you guys recommend from bmr or should I buy things separately and what to buy..it’s still all stock and need some upgrades…I don’t race the car…thx
eps cam 226/234 lsa 113+2, bfe 1 7/8 headers, rotofab cai, katech oil pump, 444 rwhp, 411 rwtq, eps tune, Blanchard performance install
camarohead is offline   Reply With Quote
Old 08-08-2022, 02:15 PM   #2
The_bald_eagle_machine
Anthony S
The_bald_eagle_machine's Avatar
Drives: 2011 chevrolet camaro 2ss/rs
Personally, I tried the lowering springs route and did not like the way the car rode. Others have lowering springs and swear by them. After wasting money with that route... I broke down and bought BCRacing coilovers... best upgrade I have done to my car yet.
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181
Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links.
The_bald_eagle_machine is offline   Reply With Quote
Old 08-08-2022, 03:10 PM   #3
gtstorey
Drives: 2010 Camaro SS2,L99, LSA SC
For 2010, upgrade to the newer style lower control arm & sway bar combo is one of the best things to do. I think it’s upgrading from FE3 to FE4 if I remember the designations correctly.
gtstorey is offline   Reply With Quote
Old 08-08-2022, 06:49 PM   #4
camarohead
camarohead's Avatar
FE4..wonder if one of the vendors has a FE4 package I can buy…see if I can find one..thx
Old 08-08-2022, 07:57 PM   #5
gtstorey
Really, FE is a GM label and would probably have to be pieced together, assuming that you can still get the parts.
Old 08-09-2022, 07:17 AM   #6
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
I really like my set up, BMR Sway bars adjustable front and rear ( order for FE4 Set up ) Adjustable Toe Rods, Trailing arms and I would get the adjustable LCA If I did it again ( I have non adjustable and It was hard to get alignment specs because I was not lowered enough for them. I have 1" Hotckis drop springs, Z/28 UPCA bushings and Hendrix solid Cradle bushings, If you are not going to do cradles then loo into Hotckis brace. If you do cradles Def do UPCA Mounts. Front I just did the radius rod inserts.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS
Stainless Works Ceramic LTH/HiFlo Cats
SCT X4 Dynosteve,
Hotckis 1" Springs & Chassis Max Brace
BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings
Pedders Radius Rod Inserts Strut tower brace
Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 08-14-2022, 01:23 PM   #7
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
The biggest difference between the FE3 (‘10-11) and the FE4 (‘12-15) is the sway bars and the LCAs. FE4 moved the mount point for the rear sway bar outboard. The FE3 mounts had a tendency to rip off under track use. The updated FE4 LCA OEM part can accommodate both suspensions.
bannonm is offline   Reply With Quote
