Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 10-12-2016, 09:01 PM   #1
camarohead
camarohead's Avatar
Drives: 2010 ss rs ls3 red-white rallys
Dealer installed 3.91 gears price
What kind of price should I be expecting having a dealership install 3.91 gears with the speedometer update?
eps cam 226/234 lsa 113+2, bfe 1 7/8 headers, rotofab cai, katech oil pump, 444 rwhp, 411 rwtq, eps tune, Blanchard performance install
camarohead is offline   Reply With Quote
Old 10-14-2016, 08:06 PM   #2
camarohead
camarohead's Avatar
I'm thinking around $1600...
Old 10-14-2016, 10:32 PM   #3
EM1/SS
Drives: 11 2SS/RS M6 vert
My install at my local garage was 300
LSA supercharger, Borla S-Type cat back, BMR/ Pedders Suspension, Kooks stepped LT's, GM 3.91, and RDP tune.
EM1/SS is offline   Reply With Quote
Old 10-14-2016, 10:34 PM   #4
jc615
jc615's Avatar
Drives: Camaro and Sierra
I'm assuming he needs them to do all of the work. I paid $300 as well but took them the parts and the differential
jc615 is offline   Reply With Quote
Old 10-15-2016, 07:24 AM   #5
Badfinger
Badfinger's Avatar
Drives: 2010 2SS
I had an estimate last year and it was $1000.00 including parts to install 3.91 gear on the car.
Badfinger is offline   Reply With Quote
Old 10-15-2016, 07:33 AM   #6
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
You can get an entire new 3rd member with 3.91and LSD for like $1800 or so? Speedo calibration is handle by your tuner(should do it for free IMHO)...
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 10-15-2016, 08:06 AM   #7
EM1/SS
I don't think Chevy will do the speedo calibration if you have an after market tune.
Old 10-15-2016, 10:49 AM   #8
havelegs
havelegs's Avatar
Drives: '23 LT1 A10
Last year was quoted at 1600
24 LT1 M6 Sharkskin Metallic
havelegs is online now   Reply With Quote
Old 10-15-2016, 01:18 PM   #9
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Paid approx 800 but I supplied the gear set from Muareen also had them replace my stock axles with a set of 1LE's.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 10-15-2016, 02:04 PM   #10
brokencilence
brokencilence's Avatar
Drives: '14 1LE, Z28.R
Why not just toss a 1LE rear diff in? They have the 3.91 gears and can be found used for $900-$1000
Far beyond stock....
brokencilence is offline   Reply With Quote
Old 10-15-2016, 03:38 PM   #11
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Where can you find one and then one at that price?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 10-15-2016, 07:51 PM   #12
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
I bought my 3.91 diff from iamgmparts.com for $1353 + $100 in shipping. Cheapestgmparts.com also has them for a comparable all in price.
Part #22806794
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 10-15-2016, 08:43 PM   #13
brokencilence
I bought one with around 9k miles off the classified section here to have as a spare for track events. now that the season is over I was going to sell it but the person that said they wanted it disappeared.
Old 10-16-2016, 04:40 PM   #14
camarohead
camarohead's Avatar
Got an estimate of $1500 with the gm parts and tune and a 1 year warranty..
