Old 02-13-2015, 11:27 PM   #1
newb
newb's Avatar
Drives: 2013 1LE
Engine choices
Everyone assumes the SS will be a V8. And the base model will get a V6 or Turbo 4 option. What if the V6 or even basic V8 was replaced with the ATS-V power plant? A TT-V6. Possibly de-tuned to 400 hp to replace the V6. Or tuned up closer to 500 hp to replace the base V8. The alpha platform is already setup to handle it and clearly doesn't have clearance issues the Stingray had when considering turbo power. How would that go over with enthusiasts?
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013
newb is offline   Reply With Quote
Old 02-13-2015, 11:53 PM   #2
bharabs
bharabs's Avatar
Drives: 18 1SS 1LE Summit White
But the information on GMAuthority does suggest that. It says V8 (LT1)
http://gmauthority.com/blog/gm/chevr...-camaro/#tab-3
bharabs is offline   Reply With Quote
Old 02-14-2015, 12:13 AM   #3
fradaj
Drives: RS
I doubt we will see the TT-V6 in the Camaro. Maybe a Turbo 4 if they can build one with at least as much HP as the one in the Mustang. All things being equal I would prefer the V8 to the TT-V6.
fradaj is offline   Reply With Quote
Old 02-14-2015, 12:53 AM   #4
MikeT
Drives: 2008 Malibu V6
Not well.
MikeT is offline   Reply With Quote
Old 02-14-2015, 12:55 AM   #5
Bhobbs
Bhobbs's Avatar
There's no point. The LF4 doesn't make more than the LT1.
Old 02-14-2015, 03:08 AM   #6
ChefBorOzzy
ChefBorOzzy's Avatar
Drives: 2016 F150
I had a dream a week or so ago that the Camaro gets the turbo 6. I guess I've been on here too much lately. Not going to happen though, at least not for now.
ChefBorOzzy is offline   Reply With Quote
Old 02-14-2015, 06:21 AM   #7
Millertime555
Millertime555's Avatar
Drives: 2016 Camaro 2SS M6
We've already heard from multiple videos that it is in fact a V8, and most likely the LT1 as the others have said.
Millertime555 is offline   Reply With Quote
Old 02-14-2015, 08:38 AM   #8
Red Chief
Drives: 2020 LT1 Black
Would it be heresy to have a performance option somewhere between the V6 and V8?
I'd rather have a TTV6 for $28k than a 2LT with a damn moonroof.
Red Chief is offline   Reply With Quote
Old 02-14-2015, 08:59 AM   #9
Z/284ever
Z/284ever's Avatar
Drives: A few Camaros
TTV6 for $28K?? I'd be surprised if you could get the normally aspirated V6 for $28K.
Z/284ever is offline   Reply With Quote
Old 02-14-2015, 09:16 AM   #10
mt3130
Drives: Coupeless :(
I would imagine that the TTV6 is at least as expensive to manufacture as the V8, and the reality is that its probably more expensive.
You also have to factor in that its performance is very similar to the V8, so even if it were possible to offer a TTV6 for $28k, GM would never do it, because they would be cannibalizing the V8, which they presumably make more money on.
mt3130 is offline   Reply With Quote
Old 02-14-2015, 09:51 AM   #11
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Detuned TT-V6 would never replace the V6.
1. Worse mileage than the V6 and would require premium fuel. The V6 is the power seller and losing those benefits would seriously jeopardize sales.
2. The engine is as costly to build as an LT1 and weights the same.
As far as replacing the V8. That's a definite no.
Old 02-14-2015, 10:11 AM   #12
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Drives: /\yes, this is me/\
I think people are going to be very shocked at the options we have when ordering the new camaro, both in engine choices and trim levels ( 1LE, ZL1, SS, etc) the 1st year
TLSTWIN is offline   Reply With Quote
Old 02-14-2015, 10:26 AM   #13
Z/284ever
Z/284ever's Avatar
There are no current plans for TTV6 in the Camaro.
Old 02-14-2015, 12:51 PM   #14
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
I see the LT1 has AFM which I hated on my L99... I had to use a Range to delete it. Now I have the V8 I wanted. So how will that be handled? Can it be disabled with a setting to avoid an aftermarket fix again? This time I assume it will affect manual trans cars too.
Cam
qcman is offline   Reply With Quote
