TireRack
Old 12-26-2023, 09:44 AM   #1
Pops
Drives: 2010 Camaro SS2 2012 C6 vette M6
Strut tower brace
I thought abought treating myself to a brace for xmas. All the how to videos show dropping struts, putting on a lift, drilling, snaking bolts,welding. I wanted a simple DIY project. Is there a struct brace that would fit a 2010 M6 Heartbeat SC camaro which is just a bolt on? Thanks.
Pops is offline   Reply With Quote
Old 12-26-2023, 11:09 AM   #2
Infidel67
Life's just a Ride
Infidel67's Avatar
Drives: 2011 Synergy Camaro 2SS/RS LS3
No Drilling Holes or tapping, just mount it on.
https://www.phastekperformance.com/b...QaAgt4EALw_wcB
Oh crap, thats an 11
2011 Synergy Camaro 2SS/RS Ls3, LTH, CAI
Custom Intake, TSP stage-3 111-LSA Cam, RWHP 503/508
Infidel67 is offline   Reply With Quote
Old 12-26-2023, 11:52 AM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yeah, the early model year 2010's do NOT have the threaded inserts in the strut tower to bolt a brace to. Unfortunately, you have to go through all that mess to install one.
1JEWLDSSRS is offline   Reply With Quote
Old 12-26-2023, 03:58 PM   #4
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
What about drilling the holes and using nutserts to bolt in with. No going under the car.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 12-27-2023, 05:27 AM   #5
Pops
Thanks for your respones and suggestions !
Old 12-27-2023, 09:11 AM   #6
vinman
The BBOMG fill-in husband
vinman's Avatar
Drives: 2015 2SS/RS 1LE AKA V1LE
Even my early build 2011 didn't have the threads either
UPSTATE C5 MEMBER
vinman is offline   Reply With Quote
Old 12-27-2023, 09:28 AM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Oh yeah, forgot about that. Mine was built July 2010, for the model year 2011, and had them. I remember checking this out before when it was brought up. So I'm not sure what the cutoff was that they started installing the inserts. Been a while. Thanks.
Old 12-27-2023, 10:18 PM   #8
vinman
vinman's Avatar
Weird, I took delivery of mine the beginning of September, so was built in August
UPSTATE C5 MEMBER
Old 12-28-2023, 08:54 AM   #9
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
I used the OEM strut tower brace with TPIS pads. But it is a bit more difficult to drill the necessary holes.
You need to drill vertical holes in the inclined sheets of the shock absorber towers.
Today I probably wouldn't do it anymore and use something from BMR.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune.
George-CZ is offline   Reply With Quote
Old 12-28-2023, 12:04 PM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Check the info sticker on the cars door jam on the driver side, it should list the "build date" there. Mine does. Says July 2010. I bought it in May of 2011.
Old 12-28-2023, 03:44 PM   #11
vinman
vinman's Avatar
I don't have that one anymore, I have the 2015 in my profile pic. But when I looked up my order status posts with BeckyD it looks like it was built the week of 8/26/10
UPSTATE C5 MEMBER
Old 12-28-2023, 03:55 PM   #12
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Hmmm, that's a weird one. July comes before August on my calendar. Not sure why yours didn't have the inserts. Oh well, guess we'll never know why some did, and some didn't. But I like your sig pic!!
Old 12-29-2023, 10:48 AM   #13
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I would not trust a nutsert to hold a strut tower brace. It needs to be through bolted for the clamping force.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
CamaroCracka is offline   Reply With Quote
Old 02-05-2024, 03:10 PM   #14
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS
Here is the BMR Strut Tower Brace for the 2010-early 2011
Sales@Phastek is offline   Reply With Quote
