Roto-Fab
Old 04-20-2020, 10:45 AM   #1
RandomTask007
Drives: Pontiac Fiero, Chevy Corvette
Timing Chain Brand
Hello all!
I'm putting together an LFX out of a 2014 Camaro for a swap (Fiero). The engine had ~100k when pulled. Changing some of the gaskets, I saw some wear on the timing chains. Due to the high mileage and the issues these engines tend to have, I'd like to change it.
My question is as follows - Are the cheaper sets (~$150) acceptable replacements? My plan is to spray the motor into oblivion (eg 200 shot). Or should I just bite the bullet and get a cloyes/melling set?
Thanks!
RandomTask007 is offline   Reply With Quote
Old 04-20-2020, 11:50 AM   #2
spyderbuddy
spyderbuddy's Avatar
Drives: 2010 RS Inferno Orange Metallic
if you already have it apart, and out of the car, put new chains on it.
the bottom end on these engines are great.
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
spyderbuddy is offline   Reply With Quote
Old 04-20-2020, 12:17 PM   #3
CamaroBarb
Drives: cheby Camaro
I'd buy the GM kit from the dealer. The reviews on amazon are saying the Cloyes kit had idler sprocket bearing failure causing engine damage. https://www.amazon.com/Cloyes-90753S...ustomerReviews
CamaroBarb is offline   Reply With Quote
Old 04-20-2020, 02:06 PM   #4
RandomTask007
Cloyes is an OE supplier for GM
I've used cloyes on multiple engines with great success. I only saw one review WRT the socket freezing... the user stated that in 4 rotations the sprocket completely froze causing the chain to jump and bent valves. I'm extremely dubious of that claim. "I'll take 'he didn't install it correctly' for $100"
Guess I'll just do it and go for the better set.
Old 04-20-2020, 02:59 PM   #5
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Your putting an LFX in a Fiero?
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 04-20-2020, 03:27 PM   #6
RandomTask007
Affirmative.
Old 04-20-2020, 03:36 PM   #7
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Originally Posted by RandomTask007 View Post
Affirmative.
Oh man, that is going to be sick. Good luck!
InFiD3ViL is offline   Reply With Quote
Old 04-20-2020, 04:13 PM   #8
Dizzy82
Dizzy82's Avatar
Why not do the 3800 swap?
Old 04-20-2020, 04:56 PM   #9
RandomTask007
Because I've done that before. And the 3800 sounds like crap.
I also think the LFX characteristics suit the car better.
Oh, and I also plan on spraying the motor into orbit. Lot easier to find replacement LFXs than it is 3800s
Old 04-20-2020, 05:17 PM   #10
ADVMax
Sporting Foole
ADVMax's Avatar
Drives: 2010 Camaro SS
An Fiero with an LSX
zero to jail in under 3 seconds!
post pics
ADVMax is offline   Reply With Quote
Old 04-20-2020, 07:01 PM   #11
CamaroBarb
There was a few that the idler bearing failed breaking off the fastener along with it. One after they had driven 1500 miles.
Old 04-20-2020, 07:15 PM   #12
Dizzy82
Dizzy82's Avatar
Will definitely be interesting to see how you are able to cram an LFX in there. What model year is the Fiero?
Old 04-20-2020, 11:21 PM   #13
mikeman
Drives: 2015 Camaro
People have done Northstar V8 swaps in them so a 60* V6 shouldn't be too difficult.
mikeman is offline   Reply With Quote
