Old 08-31-2021, 02:20 AM   #99
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
My stock bottom end build was 518rwhp thru a th400.
102
Edelbrock Pro Flo XT manifold
Milled PRC 260s
TSP 243/255 cam
Thru a manual it would have been over 550.
I now have the same build but with a 416 shortblock.
522 but a lot more torque. I went from running 11.0s full weight to 10.7s full weight.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 08-31-2021, 07:47 AM   #100
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Originally Posted by KnoxSS1LE View Post
Can't wait to see what my build does. Thanks to you guys at Frankenstein heads and cam are on the way. Any guesses on WHP?
Roto-Fab intake
Nick Williams 103mm TB
LOD intake manifold and fuel rails
1050cc injectors
Ceramic plug wires and new plugs
Frankenstein M311 heads
Cam Motion custom grind cam per Frankenstein specs
Stainless Works 2" headers and high flow cats
Melling HV oil pump
Lingenfelter thermostat
New dampener crank pulley
Upgraded timing chain
Motion Raceworks valve covers and catch can
Tuned for E-85
Car is a 2013 SS 1LE
Idk. I think it would be pretty hard to guess anything without the cam specs. But if I had to guess what your cam specs are then I would think you would be right around 550 rwhp.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 09-01-2021, 08:55 AM   #101
62nalide
62nalide's Avatar
Drives: 2013 SS
Roto-Fab intake
1050cc injectors
Melling HV oil pump
Tuned for E-85
Do you know what compression you will end up at? Supporting mods look promising
62nalide is offline   Reply With Quote
Old 09-02-2021, 11:05 AM   #102
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Roto-Fab intake
1050cc injectors
Melling HV oil pump
Tuned for E-85
Depends on dyno of course, but on a good ole 15% loss type dyno I say, if the cam and valvetrain are good for high rpm, 555rwĥp. Cam spec and valvetrain details would be good to know...
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 09-03-2021, 12:15 AM   #103
Bo White
Bo White's Avatar
When I first did my th400 swap once I got the tune and stall converter dialed in I went from making 478rwhp to 437. Reverse math that would be 560 crank with 15% loss and 22% loss respectively. I figure I'm making 689hp now at the crank since its 537rwhp now. That would be 585rwhp thru a TR6060. That's not too far fetched.
Edit: these are E85 power numbers. Previous post was 93
Totalled:
500, all motor, ls3
