03-09-2018, 11:19 AM | #1 |
Drives: 2017 zl1 a10 Join Date: Oct 2016
Location: Missouri 2017 zl1. Cammed, magnuson 2650 973whp 889ftlbs
What size skinnies fit up front?
Just trying to find out what size wheels I can fit up front for drag racing and the best place to get them
03-16-2018, 11:50 PM | #2 |
Drives: 2019 Jeep Rubicon Sold:2017 ZL1 A10 Join Date: Feb 2017
I need to know this to
Travis
SOLD ZL1 Summit White, A10, Black Strip, PDR, ZL1 floor mats Ordered 2/11, 2000 2/14, 3000 2/20, 3100 2/24, 3300 3/7, 3400 3/8, 4300 3/16, 4B00 3/21 Bayed at train yard in Ohio, 4200 3/26 All Abroad for the West Coast, 4800 4/4 Deliverd to portland train yard, 5000 4/7 3:00AM Deliverd to Dealer, 6000 4/7 6:45PM Delivered to Customer |
03-17-2018, 04:12 AM | #3 |
Drives: 2017 White ZL1 A10 Join Date: Mar 2016
Carlyle Racing can get you hooked up they said 18x6 alumistars will fit but are a pretty penny. http://www.camaro6.com/forums/showth...highlight=18x6
I'm running Weld 20x5 fronts on my car.
2018 Trackhawk
2017 ZL1 A10 2017 CTSV 2016 GT350 2015 Hellcat Challeger |
03-17-2018, 06:48 AM | #4 | |
I have RTS S71 17"x10 for the rear. Would love to match the front with the rears. What specs are your 20x5's? What tire did you go with? I did not install the TPMS? Any and all info helps a ton, thanks a lot!
Travis
03-17-2018, 11:53 AM | #5 |
That car is jaw dropping on those wheels/tires. Nicely done.
03-17-2018, 12:32 PM | #6 |
Here are the specs I purchased them from (threat) in the for sale section he had the the lip powder coated black too got a smoking deal and he purchased from Carlyle Racing were I purchased my rear 17x10 beadlocks. Tires are Bridgestone 195/50/20 speed rated 168+ mph wanted a tire I could run on the street.
2018 Trackhawk
03-17-2018, 12:36 PM | #7 |
Few more pics
2018 Trackhawk
03-17-2018, 08:30 PM | #8 | |
Travis
03-26-2018, 11:30 AM | #9 |
I had so many issues trying to get a good fit. Seems Carlyle has it figured out for the 6th Gen.
We should also start seeing these coming from GM Performance Parts in a 15' with rear brake mods too. This 5th Gen on 15's looked sweet this weekend. |
03-26-2018, 03:44 PM | #10 | |
15in kit
03-27-2018, 11:36 AM | #11 |
Drives: 2017 Ford F250, 2019 Lincoln Navi Join Date: Apr 2016
Weld has told my wheel guy a 17x5 will fit up front. I have it in my truck ready for a test fit, but had another weld rep say a 20 was needed, along with carlyle. Should know soon...
Instagram: MattZ_L1 Vengeance Racing Built
03-27-2018, 05:40 PM | #12 |
USN VET
Drives: 2016 SS sedan, 2018 ZL1 1LE Join Date: Jun 2017
Was messaging Carlyle last week and was told only the S79 will fit in the 18x5 from weld, the way the other RT-S wheels are made/ curve inside hit the calipers. I'm considering the full set of S-79s rear/17x10 front/18x5. I have a 1LE and was wondering if a 17x10.5 will fit in the right offset. I've plugged in numbers on the fitment calculator and it says the wheel will fit, but everyone else has said no because of the lower A-arm, anyone near LA that wants to help test fit a 17x10 to see if I can go .5 wider. This is so I can fit different tires if the first tire doesn't work with my setup.
HUZL1N_1LE
03-27-2018, 07:48 PM | #13 |
Still running the race stars 17x9.5 and 17x4.5. 28x5-17 hoosiers and 28x10 slicks in the rear.
06-09-2018, 04:40 PM | #14 |
Drives: 6th Gen NicKey Camaro & others. Join Date: Nov 2015
S71 Weld 17x10 rears and 17x5 fronts with the 4 pot Brembos fit, but the the 17x5 fronts do not clear the ZL1 6 pot calipers.
