12-23-2021, 08:50 AM | #1 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Anyone have a write oup for all of the Specs needed for Gear/Carrier install?
Hi,
Going to be installing 3.91 GM Gears and a TrueTrack in my 14 2 SS/RS. I have a Ratech Install kit and an extra Pinion bearing for mock up. Does Anyone have all of the specs for the install? Will it come with the gears ( I am getting them shortly and ordering the TrueTrack today ) Using Torco RGO 80W-90 FLuid. I'll probably drop the cradle and do the Z/28 UCA and Hendrix Solid Cradle bushings at the same time. I am looking for all of the Specs for the complete install, Torque specs of driveshaft as well. Thanks
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
12-30-2021, 09:09 PM | #2 |
Anyone?
