dave@hennessey
Old 08-24-2010, 02:45 PM   #1
advfire
advfire's Avatar
Drives: 2010 SS Black
New Dyno Numbers - 638 RWHP - 624 RWTQ ( what the HP at the block )
2010 camaro LS3 motor-Ran a test on a new mustang DYNO today. car hit 638 rwhp and 624 rwtq. many people have made comments that the mustang numbers are more true but are about 8 to 12 percent below and dynojet, in addition the flywheel horsepower would be even 12 to 15 percent more. At my present numbers at the rear wheel would this mean my motor is pushing 775HP at the flywheel, does this sound right???
advfire is offline   Reply With Quote
Old 08-24-2010, 03:10 PM   #2
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Using a 15% loss, it would be closer to 750 ...
SlingShot is offline   Reply With Quote
Old 08-24-2010, 03:13 PM   #3
JANNETTYRACING
JANNETTYRACING's Avatar
What is your Set up?
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 08-24-2010, 03:41 PM   #4
AndrewZPSU
Drives: 2014 Corvette M7
Easy way to figure your wheel hp to engine hp is to divide by .85... or .8 for an auto.
AndrewZPSU is offline   Reply With Quote
Old 08-24-2010, 03:58 PM   #5
TommyTSquared
TommyTSquared's Avatar
Drives: RSSS
Or if you want to go from rwhp to flywheel... multiply by 1.15 or 1.2 for an auto!
math is fun!
TommyTSquared is offline   Reply With Quote
Old 08-24-2010, 04:05 PM   #6
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
math is fun!
not too fun as that doesn't work out ...
ex.
650 / .85 = 764.7
650 * 1.15 = 747.5
I think the / .85 way is correct ..
Crowley
Crowley is offline   Reply With Quote
Old 08-24-2010, 04:07 PM   #7
advfire
advfire's Avatar
maggie with 10 lbs bost
stage 2 cam
CAI
kooks 3' full headers to tip
meth injection
160deg ther
question is if you all think 750 would be a valid number using a mustang what do you think i would get using a dynojet?
Old 08-24-2010, 04:08 PM   #8
midgard
midgard's Avatar
Drives: red jewel camaro
Multypling by 1.15 is more reasonable.
If a typical stock ls3 is 370...multiply that by 1.15 and you get 425.5
2010 Red Jewel Camaro ss/rs
A6/L99 POWER NUMBERS....874 rwhp/880 rwtq!!
9.81@142.02
Livernois 2nd Place Car Camaro5 Fest
Original Build 13 psi/nittos.....10.44@134
3.6KB/3.5 pulley/Stock t/b..Best 9.967@142.01
SSJ3...is done....mid 9s?Rossler 6l80E Transmission
KB 3.6LC,17" Bogarts, Thanks to Hendrix 9", Thanks to Pfadt
original T/b and converter, 419ci stroker (NO LSX Block)
midgard is offline   Reply With Quote
Old 08-24-2010, 04:12 PM   #9
TommyTSquared
Drives: RSSS
ex.
650 / .85 = 764.7
650 * 1.15 = 747.5
Crowley
brb... doing this on pen and paper! lol
So the formula would be: x(1-y) = z
x = flywheel
y = % (15 for manual and 20 for auto)
z = rwhp
going from rwhp to flywheel would be: z/(1-y) = x
Old 08-24-2010, 04:15 PM   #10
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
stage 2 cam
CAI
meth injection
160deg ther
it depends on how the dyno was set up ...
Just say the mustang dyno reads say 3 % lower than a dynojet ..
638 / .82 = 778
On a dynojet it could read 661 rwhp (778 / .85)
Again .. all depends on how the dynos are setup etc .. use the dyno as more of a tool for mods and see differences ...
Crowley
Old 08-24-2010, 04:16 PM   #11
advfire
advfire's Avatar
manual,
i guess the real question is if im getting 638 on a mustang what would i get on a dynojet and then what would be my end horsepower
Old 08-24-2010, 04:18 PM   #12
advfire
advfire's Avatar
manual,
reason being is that the orignal horsepower rating from chevy was posted on a dynojet, using the same type of gauge would be what i would compare with...
Old 08-24-2010, 04:38 PM   #13
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
manual,
I'm not sure what you mean by end horsepower ... in the post just above this one I have an example (say if there is a 3% difference between a mustang and dynojet numbers). Your Engine HP is constant and will be the same on both, but your rear wheel HP will be different because one will read say 15% loss and the other maybe 18% loss ..
Crowley
Old 08-24-2010, 07:20 PM   #14
advfire
advfire's Avatar
Crowley
i guess it was my understanding that a mustang was about a 8% difference then a dyno and then 12% to 15% loss to the wheel. this is what i was interested in knowing
Texas Speed Long Tubes & Rumbler 5 Cat-Back Dyno Results! Trevor @ Texas Speed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 48 12-08-2018 02:37 AM
Camaro SS 2010 on dyno makes 364 whp & 371 rwtq !! Vid inside UCF w00t Camaro Photos | Spyshots | Video | Media Gallery 128 03-20-2011 10:27 PM
V6 Camaro Dyno numbers are in!! MadMaxx Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 145 10-07-2009 06:38 PM
Another set of dyno numbers plus.. scrming Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 25 07-10-2009 04:47 AM
Dyno numbers for axle-backs? LDGn63 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 07-08-2009 06:20 PM
