03-12-2019, 12:17 PM | #1 |
Drives: black2ss Join Date: Jul 2010
Hooking up nitrous oxide
I have a NOS wide open throttle window switch and need to know why do I hook the wires up to to get the signal also is our TPS throttle position sensor signal rising or falling thanks
03-13-2019, 04:03 PM | #2 |
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX Join Date: Mar 2011
TPS is rising. You'll want to look up the nitrous outlet installation directions for the NOS switch on their website for the exact wires to tap for TPS and tach, but it is very easy to install.
2011 Camaro 1SS
Whipple Supercharged street monster |
03-13-2019, 04:13 PM | #3 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Green wire at TB. Falling edge, iirc. Nitrous Outlet has a harness with a pigtailed wire for that hook up. Purple wire, rising.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
03-13-2019, 06:09 PM | #4 |
thanks
