07-17-2018, 01:36 PM | #1 |
Drives: black2ss Join Date: Jul 2010
Vararam DRX
Has anyone tested the new vararam against the old vararam and which one do you think is better I have both and just need to know which one is better for anyone that has tested it thanks
07-17-2018, 06:33 PM | #2 |
I doubt it.
Reason? Their stupid marketing makes it seem as though you cannot install the DRX on a 2010/2011 Camaro, which is absolute BS. Now, you cannot install a 2010/2011 Vararam SS on a 2012+ car due to the radiator neck relocation, but you can certainly install it the other way around (DRX on a 2010/2011). I can understand why they did it though. After the amount of $$$ they put into the original Vararam, why would they want to kill it off and compete with their own product by saying the DRX can fit those cars too? I am very happy with my Vararam SS, and contrary to most other people, I love the way it looks, and even more so, the way it performs. That said, I would love to try a DRX and see how it performs in comparison.
07-18-2018, 08:01 AM | #3 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Ive asked them before and they have told me the gains are similar. But, I'll bet the OTR intake will offer better throttle response and lower IATs compared to the DRX.
Run whichever one you like, they're both good options actually i know the OTR will have better IAT's. for the past couple of logged WOT runs i've logged IAT's at ambient temps or 1 degree above. cruising its about 3-5 above ambient temps
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 Last edited by xc_SS/RS; 07-18-2018 at 12:29 PM. |
07-18-2018, 01:31 PM | #4 |
Drives: 2014 C7 Join Date: Oct 2013
The DRX will fit on a 2010-2011 V-8 Camaro . They make similar power.
The reason we don't offer it for the 2010-2011 car is because GM changed the algorithm in the ECM. The DRX is designed to maximize GM's ECM 2012-2014 V-8 programming out of the box without tuning. If you put it on a 2010-2011 the tune would be off. |
07-18-2018, 02:18 PM | #5 | |
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
07-18-2018, 03:27 PM | #6 |
It has to do with revised MAF limits ,scaling , sensitivity and it's correlation to the Trans and cam timing on automatic cars .
VR tech |
07-19-2018, 01:31 PM | #7 |
Vararam
I have both vararam the o t r and the drx and my car is it 2010 that's been tune and I will be testing them at the track and a week or so at pbir will let everyone know when I am done
07-19-2018, 02:30 PM | #8 |
FYI:
The DRX is setup for a 2012-2014 Camaro that has a completely different MAF scaling rate than a 2010 model. If it is tuned for the 2010 OTR unit it will be completely off for the DRX and Vise Versa. This will affect max commanded Ignition and Cam timing ( if an Auto) as well as the Air fuel ratio. When compared tune for tune the DRX will out ET the "standard" VR OTR. Trap speed will be about the same. The DRX is designed to make more Torque and Power under the curve . That is what it has proven to do, even when compared to others on the dyno . It spikes up another 10HP and Ft lbs and carries it up until about 5850 RPM unless there is a cam change. We had a customer just last week Dyno it against another popular CA based brand on a heads cam car. The DRX made 22 more ft lbs of Torque and 14 HP more on the dyno TUNE for TUNE. The DRX manipulates the air-charge velocity to over 100% VE at a specific RPM point. The OTR unit uses Ram affect to do the same but at a higher RPM point. VR tech |
07-19-2018, 05:46 PM | #9 |
vararam
i have gpi ss1 cam gpi tune gpi ported and rod mod intake long tube header ported throttle and went 11.6 at 120 with the OTR vararam last time i was at the track just want to see is the drx going to pick up anything also going data log so Ryan can adjust the tune for the drx
07-19-2018, 07:39 PM | #10 |
If retuned it will pick up.
Did you get that OTR VR from Ryan or from US? In other words ,is that his old OTR unit? VR tech |
07-19-2018, 08:08 PM | #11 | |
07-20-2018, 04:49 AM | #12 |
vararam
yes it a old OTR got it years ago
07-20-2018, 07:27 AM | #13 |
Well now I'm curious about the DRX unit lol I might give it a shot at some point
2010 2SS/RS
07-20-2018, 08:09 AM | #14 |
Vararam
The only reason I changed to the DRX is because the OTR would not fit what my nitrous plate so I guess I need to have Ryan retune the car for the DRX unless you can come up with a solution to make the OTR with the nitrous plate would love to keep the OTR and do you think I need to update the old OTR it's about 9 years old one of the first ones you made do you think I need to change to the new OTR this question is for vararam are Ryan thanks
