12-23-2010, 03:33 PM | #1 |
Drives: 2010 Join Date: May 2010
2010 Boston acoustics back speakers rattle? "Bulletin: can't fix, normal" ??
I took my 2010 LT camaro into the dealer this morning to have them check out a rattle coming from the rear speaker area that started happening about a month ago.. the rattle is only when the speakers are playing low/bass tones.
I just received a call informing me that they found a bulletin on the issue which states "it is normal for the speaker itself to rattle and make a vibration noise heard throughout the car" so they can't/won't not fix it. This doesn't seem acceptable to me. The boston acoustics was a $450 upgrade for the LT version I purchased. I've had my camaro since march and the problem just started happening about a month ago, so it is not "normal." Do you guys have any advice on the matter? Thanks |
12-23-2010, 04:36 PM | #2 |
Drives: 2010 SS loaded Join Date: Sep 2010
speaker rattle
Take a small piece of foam and wedge it between the black tab on the side of the speaker. The tab has #'s on it and says Boston Acoustic on it. Wedge the material in good and the rattle will go away. I know it sounds cheap but it works.
12-23-2010, 04:53 PM | #3 |
376 cubic inches of fun
Turn down the bass.
12-23-2010, 04:54 PM | #4 |
Drives: 2018 Camaro ZL1 Join Date: Nov 2009
happend to me right when i bought it took it to the dealer and got it replaced
2018 ZL1 M6 NGM
PPF and Ceramic coating IG: NGMZL1 2010 2SS RS --- SOLD MODS- Performance: BMR trailing arms & bushings | BMR Toe links | X-pipe | Muffler delete | Vmax ported throttle body | Apex "strong" MAS | Vararam CAI | Apex catch can | Kooks Headers | Kooks HF Cats | Dyno tuned by GPI 417 RWHP 409 FT-Lb Cosmetic: painted Zl1 rockers | Zl1 grill | AAC side markers | AAC LED backup lights | windows tint | taillight tint | JDP tow hook | all emblems blacked out | LED fogs |
12-23-2010, 05:13 PM | #5 | |
All it says is specifically "do not replace the speaker this is normal performance it will not fix the problem." Seems weird that this is "normal performance" if it didn't happen to me for almost 10 months and yours was fixed with a simple replacement. |
12-23-2010, 05:17 PM | #6 | |
I asked the service tech if something of a similar nature would work and he said the speakers were already coated in from but it could work because the clips are why it rattles. |
12-23-2010, 06:48 PM | #7 |
Drives: 2010 Camaro 1SS L99 A6 Join Date: Nov 2010
Can you take a picture? Thanks.
The Most Interesting Man in the World - On Muscle Cars
"I don't always drive muscle car, but when I do, I prefer the Camaro. " |
12-23-2010, 09:27 PM | #8 |
Drives: 05/07 Chevy's Join Date: Aug 2009
Heres the bulletin your refering to.
12-23-2010, 10:04 PM | #9 |
Not to thick, I would use the foam you use to insulate around a door. I used a piece of sound deadning carpet, just a 1 inch x 1inch piece. Then went inside car wear the rear deck meets the side pannel in back and stuffed some in there also (i'll take picks tomorrow) takes away from small rattle inside of car
12-23-2010, 10:39 PM | #10 |
12-23-2010, 11:25 PM | #11 |
Camaro SL,UTs
Drives: 2010 Camaro SS/RS #16429 Join Date: Sep 2006
I'm sorry to say this but more and more "it's normal" is starting to become a common response to many issues when I take in any of my Chevrolets in for warranty claims.
12-24-2010, 12:15 PM | #12 |
Drives: 1991 New Yorker, 69 Tbird, ABM2SSRS Join Date: May 2009
I agree it seems the service representatives are getting extra lazy
12-24-2010, 06:06 PM | #13 |
I guarantee that no store would have much luck selling a multi-hundred dollar sound system if they made it know the system rattles during normal performance and creates a nice vibration noise during the low tones..
I'm giving GM a break for the holidays, but I will definitely call the # specified to escalate the issue. |
12-24-2010, 06:26 PM | #14 |
So It'll Go Down Easy
Drives: Camaro SS/RS Join Date: Aug 2010
Just curious (maybe I should start a separate thread)...
How do you have your audio controls adjusted? I keep mine around (off the top of my head)............... Hi: 7 Mid: 4 Low: 8 Balance: Center Fade: Rear 1 or 2 I've found this to work the best for me. I listen to pretty much everything, but on some rap/hip hop albums I have to cut the low end down to 2-4 instead of 8. And on older, non-remastered rock albums (such as old Blue Oyster Cult albums), I'll crank the low end up to 12. |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Photos of Stock Speakers: Boston vs Non Boston | Steve@Subthump | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 12 | 01-03-2015 11:43 PM |
No sound from Boston Acoustics speakers | tony_c | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 10 | 09-10-2012 12:22 PM |
Press release: 2010 Camaro Audio by Visteon and Boston Acoustics | Mike C | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 49 | 07-07-2009 02:11 PM |
Cloth Seat Back Rattle with fix | shiftz33 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 5 | 06-18-2009 10:20 PM |
