06-06-2017, 10:10 PM | #15 |
Drives: 16' Camaro 2LT RS Join Date: Aug 2016
Same here.
Have the Escort Max with the BlackVue 2channel dash cam. I have the Constant wired directly to the thick battery wire running near the center console and I grabbed the acc. power from the BCM. I have the cam running into the PowerMagic Pro for parking mode. |
06-07-2017, 12:46 AM | #16 | |
Drives: Duramax Join Date: May 2017
Remember, some of the late mode ECU's have active electrical load managing and if they sense a parasitic load, (after you add an extra amp load to a rated circuit), it possibly can cause all sorts of electrical gremlins/issues. |
06-07-2017, 08:24 PM | #17 |
The calculation to find out the amperage of a circuit is fairly simple. Divide the Power by the voltage it takes to power the unit. The answer is your amperage. Formula: P/E=I or simply add up the amps your radar detector and dash cam use, should be fairly small. But with this said, you definitely do not want to tie into any circuit dealing with your airbag, even if it is just the airbag indicator light and you also want to stay away from the ECU. The BCM on the camaros are extremely easy to get too, located right above the pedals and it is safe to tie into the accessory or ignition power from here just make sure to fuse your wires.
06-07-2017, 10:54 PM | #18 | |
Drives: Camaro Join Date: May 2017
06-07-2017, 11:16 PM | #19 |
I do not remember the pin locations off the top of my head but I'll be at work tomorrow and get that info posted for you. I'll also supply the actual wire colors and the color of the harness you'll be splicing into.
06-08-2017, 06:14 AM | #20 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Norm
'19 WRX 6M (the family sedan . . . seriously) |
06-08-2017, 09:43 AM | #21 |
-12volts (Constant): located at the blue plug, pin 4. Wire color: Red/Grey (Red wire with Grey stripe.
-Accessory (Switched Power): Located at the green plug, Pin 5. Wire color Purple/Yellow (Purple with a Yellow stripe) ...... Norm Your right that it's not just current draw that matters when tying into modules but not all modules use load sensing or even MUX signals. The camaro does not when it comes to these SPECIFIC circuits discussed (the Constant and Acc.. Power). Your correct about the airbag circuit thus why I recommended against it. |
06-18-2017, 09:24 PM | #22 |
Drives: 2LT/RS v2.0 & 2016 2SS Join Date: Jul 2013
Did you have a thread on this? Just wondering. Im thinking of doing the same thing. Just scared it may overload or create some issues in the future.
i dont just drive... i drive a CAMARO .. name is IRAQ.. born from blood and sweat.. ripping roads.. and now proud to announce, SPARKY, the new addition to the family.. my 2SS baby... #fasterthanaspeedingticket
