06-18-2017, 04:23 PM | #15 |
Drives: 2017 Camaro 2SS 6M Join Date: May 2017
This just happened to me yesterday. After I pushed down on the lid, then it would pop open. I give the trunk lid a firm close now. It seems to open fine.
Sent from my iPhone using Tapatalk |
06-18-2017, 10:26 PM | #16 |
I've had some issues with the trunk not opening with remote. I had determined that it just wasn't fully closed, and used the button to open it. Hmmm now I wonder if there isn't something else going on?
06-18-2017, 10:32 PM | #17 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
the hight adjusment is very touchy. a little too low and it will not have sufficient force to pop up when the lock is released.
ie, if i remove the center plastic peace in the middle of the trunk opening on the car, the trunk will fail to pop. Put it back on and it forces the trunk up a little while closed. Popping works as expected. You should be able to see a little indentation onn the center plastic panel somewhat near each side along one of the plastic ridges. If you dont see any "damage" here, then the trunk may need adjusting. |
06-19-2017, 11:25 AM | #18 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Yeah, exactly this.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
01-20-2019, 04:35 AM | #19 |
Drives: '16 2SS Join Date: Nov 2009
I have this issue now. Does anyone know if there is a service bulletin?
My Intro Post | My Order | My Ordering Guide
TJCR2Q | 2SS Red Hot|Adrenaline Red|MX0 A8|56R Wheels|5ZU Blade Spoiler|NPP Exhaust|F55 MRC|IO6 Nav 4/06/16 1100 Ordered (waiting for 5ZU acceptance) 4/19/16 2000 Accepted with 5ZU 4/23/16 3000 TPW:5/16/16 5/06/16 3100 5/13/16 3400 Broadcast Sheet 5/24/16 3800 Vehicle Produced 5/25/16 4B00 Bayed 5/27/16 4300 Intermediate Delivery 7/9/16 Delivered! |
01-20-2019, 11:41 AM | #20 |
I would suspect the microswitches in the latching mechanism before any controlling module or fuse block. These are probably not separately serviceable as a GM part.
01-20-2019, 02:28 PM | #21 |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
I wired up a pigtail directly to my battery and hooked up a CTEK charger to keep the battery alive over the winter when the car is stored in the garage until spring.
I ran the charger cord out of the trunk up to the roof and into a ceiling outlet where there were 2 sockets but the door opener only needed one. I figured this way there was no additional path up into the car for mice like if the cord was on the garage floor. Anyway, I figured that the big fat rubber seal on the trunk deck would squish around the cord, so I closed the trunk. One I did that, it would not open again with the remote or with the little rubber button. I guess the cord was holding the trunk lid out of position? Anyway, I got into the car and flipped down the rear seat backs and used the manual release[1], which worked fine. I did not re-close the trunk lid all the way, since the cord is still in place. I am somewhere around 6'3" so I REALLY had to contort myself to get in there and do that. It was not pretty.
