10-11-2018, 12:05 AM | #1 |
The Mechanic
Drives: 1SS M Join Date: Dec 2017
The weight thread
So I figured since no active thread exists to collect this data, that I will pick up and try to consolidate the information from the forum here. Originally posted in the road course section but i figured it can help more people here.
Powertrain 2016 SS A8 full exhaust NPP Mufflers with 6" of pipe going in 39.30 lbs Complete mid section and cats 59 lbs Exhaust manifolds (pair) 23.60 lbs Complete OEM SS A8 exhaust front to back with NPP 121.90 lbs (anthony@lgmotorsports) Non NPP (turbo specifically) muffler equals 32 lbs. Full catback comes in at 52 lbs. Downpipe is 15 lbs (corner carver) Stock SS m6 driveshaft (no carrier bearing) 24.4 lbs. Gforce 3.5" Aluminum 20.8 lbs (Dubchitts) stock intake manifold(no throttlebody)/plastic top cover/camaro side engine covers 15 lbs (Nightfall SS) Battery 46lbs (snowblind) Suspension 2018 stock 1ss 20" wheels and tires (2k miles of wear)front 61.2 lbs rear 64 lbs (Joey Soul) Camaro SS 1LE Forged wheel with tire was 55lbs (Rear) (G2K) Stock GM front strut tower bar 2.9lbs (aluminium) BMR strut tower bar 7 lbs (steel) (corner carver) Stock Front SS rotors 25.8 lbs (turbo8u) 6 piston rotor 27.4 lbs (locktyght) 4-piston caliper 12.8lbs (drained) 6-piston caliper 13.2lbs., all measurements including pads, clips and pins (grnflash) LT 18 inch wheels 24.4 lbs (PolynesianPowerhouse) SS 20 inch wheels front 61.2lbs rear 64lbs (joey soul) 2016 Camaro LT Front: Rotor 20.6lbs each Caliper 15.8lbs each (Scoooter12) Body Front passenger seat 55 lbs Rear seats (both portions combined) 21 lbs (joey soul) 2016 Convertible 2SS Leather Rear seat (non-folding back & bottom) 23lbs (driven2exceSS) 1LE Recaros 55 lbs (aa406079) Accessories Camaro all weather floor mats are 10 Flat tire kit 7-8lbs Trunk big Camaro all weather mat was another 8lbs (G2K)
BTR 225 w/CNC Heads|JLT intake|Speed Engineering 1"7/8 long tube and mid pipe|LT2 manifold w/95mmTb|Self tuned w/HPtuners|Silvers 2Way coilovers|Hotchkis front sway|Advan AD08R|BMR solid cradle bushings|Recaro SR7| Work ZR10 19"
10-11-2018, 11:06 PM | #2 |
Drives: 1LE Join Date: Sep 2017
What does a fully loaded door weigh with everything glass switches door panel etc etc
10-12-2018, 06:06 PM | #3 |
The Mechanic
This is just a collection of data, when someone gives me the weight or I find it in a thread on here I will then add it too the list.
10-12-2018, 09:30 PM | #4 |
Drives: 2017 2SS Manual Join Date: Apr 2017
What is the approximate weight of a Burger King Chicken sandwich?
10-12-2018, 11:49 PM | #5 |
Drives: 2018 1SS Join Date: May 2015
Stock rear tires and rims ( Goodyear run flats 20 inch ) 61 pounds each..
Race star 17/10.50 rim with M/T 305/45/17 tires 47 pounds each .. For two rear tires that is a weight saving of 28 pounds of rotating weight .. |
10-13-2018, 08:54 AM | #6 |
01-17-2019, 12:28 PM | #7 |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
Rear seats is wrong. Bottom is 11 lbs top is 18lbs... looking for my pictures of when I weighed everything...
Camaro all weather floor mats are 10 Flat tire kit 7-8lbs Trunk big Camaro all weather mat was another 8lbs Camaro SS 1LE Forged wheel with tire was 55lbs (Rear)
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
01-17-2019, 12:52 PM | #8 | |
The Mechanic
I will add your new data as well.
01-17-2019, 02:46 PM | #9 | |
@Blackmamba_1LE
Only difference on a 1LE is that they are leather, just like the 2SS seats
01-27-2019, 11:21 AM | #10 |
@Blackmamba_1LE
I finally took the seats out yesterday to have some mexico fun. Here it is on a hook scale which i believe is best with large parts to avoid improper distribution.
So like i said before the 1LE have leather back seats, same as the ones that come on a 2SS. For a total of 30lbs in both.
02-19-2019, 04:44 PM | #11 |
The Mechanic
Ahh its the leather. Mine are cloth from a 1ss. Ill post the leather weights as well then
02-19-2019, 05:07 PM | #12 |
376 cubic inches of fun
If you want a light weight car, get a Porsche. They have 4 cylinder cars that will kick Camaro's ass in the 1/4 mile. Burt they don't look or sound like muscle cars.
02-19-2019, 07:35 PM | #13 |
Drives: 2018 1SS Join Date: Dec 2018
Was there another weight thread, or did this one get cleaned up? I though I saw trunk lid with spoiler, fender, doors, A8 drive shafts and more in the past.... anyone know?
2018 Red Hot 1SS, GM lowering kit & 1LE Sway bar kit, ZL1 1LE solid rear cradle bushings, BMR sway bar end links, GM CAI w/tune, Pray ported IM, Mamo ported TB, VS Forged VS07 rims 20x11 & 20x10 w/ Michelin PS4S
02-20-2019, 09:42 AM | #14 |
Drives: SS A8, NPP, Red Hot Join Date: Jan 2019
Didn't see the NPP muffler weight on there, only the non-NPP. I will be cutting mine off to install an axleback (screw valve rattle!) on Saturday and I will weight it. This is dependent on how long they will have my car for the new flush procedure. I take her in tomorrow.
