TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 08-14-2014, 08:58 PM   #1
z28-conv
z28-conv's Avatar
Drives: '97 z-28 conv. 2013 BRM ZL1 conv.
DOES ANYONE HAVE AN OIL CONSUMPTION PROBLEM?
Hello everyone. I was just about to schedule an appointment with my local dealership to have an oil change the other day. I went to start the car and the info screen put up a message that said "Low oil level, Add oil". I checked the dipstick and indeed it was low. I had an appointment today and I intentionally left the oil level low so it could be seen. I asked the tech, how low was it? He said "2 QUARTS" I asked him how the h--l can a 17000 mile car be consuming oil? I want to know if anyone else has experienced this? I can tell you the car has not been to the track yet and I just replaced my first set of tires about 500 miles ago (16,500 miles).
z28-conv is offline   Reply With Quote
Old 08-14-2014, 09:09 PM   #2
Vroom
Drives: 2013 Camaro ZL1
I lose about a quart every 5k miles/oil change
  • 2013 Victory Red ZL1 - 210K+ miles. Mods: Who needs mods...its a freaking ZL1 - Last car: 2006 GTO
Vroom is offline   Reply With Quote
Old 08-14-2014, 09:44 PM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
as hard as I have run my ZL1, I have not had to add one drop between changes (approx 5k miles). This includes many laps at VIR too.
Old 08-14-2014, 10:10 PM   #4
CanadianZL1#992
ANGRY Z
CanadianZL1#992's Avatar
Drives: 2015 Camaro ZL1
2015 ZL1 A6 396 stroker RWHP- depends on nitrous
CanadianZL1#992 is offline   Reply With Quote
Old 08-14-2014, 10:16 PM   #5
MIZL1
Drives: Just a few!
Originally Posted by CanadianZL1#992 View Post
I haven't needed to add oil either (Mobile 1), changing at 3k and using a catch can, collecting 3-4 oz between changes.
MIZL1 is offline   Reply With Quote
Old 08-14-2014, 11:43 PM   #6
jon6.0
Going for Plaid
jon6.0's Avatar
Drives: 2011 C6
They may not have filled it up with the correct amount initially. ZL1's take more oil than an SS.
2014 ZL1, manual trans, carbon hood insert, Rotofab, Pacesetter 1 7/8" headers, 1" drop BMR springs, stock pulleys, 91 octane tune, 545rwhp & 515rwtq
Serviced and modded by Cordes Performance.
2011 C6, 750rwhp, forged LS3, ported LSA heads, Vortech Ti-trim, 227/243 115+4 Lunati cam, ported LS3 intake, Alky Control methanol, Pfadt sways/shocks/trans mounts, Pfadt tri-y headers(Sold 6/28/14)
jon6.0 is offline   Reply With Quote
Old 08-14-2014, 11:45 PM   #7
silverds
2015 SS 6M
silverds's Avatar
Drives: 2015 SS 6M
I have added 2 Quarts in the past 5000 miles, each time after the Low Oil warning. I'm at about 28k now. I drive my ZL1 daily. I do tend towards "spirited driving". I often wind first gear out to 35-40mph, and cruise at 40-48 in 2nd gear. I rely heavily on engine deceleration, so I sometimes down shift to 3rd gear at 80-60 to 2nd at 65-40, and first at 45-0. Increased oil consumption, is somewhat expected in my situation, however I am monitoring it much more closely now and keep two quarts in the trunk, always.
silverds is offline   Reply With Quote
Old 08-14-2014, 11:56 PM   #8
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
Those of you that are using oil, what was the break-in procedure you used when the car was new?
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 08-15-2014, 12:00 AM   #9
BAD ZL1
BAD ZL1
BAD ZL1's Avatar
Drives: 2013 VIN 48 Victory Red ZL1!
Bone it like you own it....
BAD ZL1 is offline   Reply With Quote
Old 08-15-2014, 12:15 AM   #10
jon6.0
Going for Plaid
jon6.0's Avatar
Drives: 2011 C6
I don't use oil in mine. I also was hitting redline and using engine braking from day one. I don't believe in extended break-in periods. A couple of heat cycles and give her hell is how I do things.
Old 08-15-2014, 12:24 AM   #11
LuckyZL-1
Ragtop Rocket!!!
LuckyZL-1's Avatar
Drives: Black on Black Convertible
I change oil every 2000 miles and give it hell all the time. It stays full with the exception of the couple of ounces in the catch can. Oh and I didn't follow the break in at all!!
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package.
744rwhp 727rwtq
LuckyZL-1 is offline   Reply With Quote
Old 08-15-2014, 06:43 AM   #12
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
OP how many miles since your last oil change prior to the 17k mark? 1 quart every 3k miles is acceptable oil consumption. Maybe it wasn't filled all the way last time. Lots of variables here...
'19 Z06-7Speed and lowered on stock bolts
'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew
TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0
SOLD! '18 ZL1 Mosiac Blk
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 08-15-2014, 07:19 AM   #13
CAM....ZL1
CAM....ZL1's Avatar
Drives: 2012 ZL1
+1, no oil consumption here either. a small amount in the CC once in a while. Has always been full on the stick. I did watch a tech try to only put in 7 quarts and stopped him to let him know he was a little short. the owner and manager lit him up because they know how paticular I am about my car.
CAM....ZL1 is offline   Reply With Quote
Old 08-15-2014, 08:25 AM   #14
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
See how it does at 3,000 miles. If you can get 3k miles without being a quart down then I'd settle for that; Make sure that the oil gets changed at that mark.
Let the dealer do an oil analysis (it used to be termed oil economy test) to see if there's a potential problem somewhere.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
lbls1 is offline   Reply With Quote
