06-19-2014, 10:04 AM | #57 | |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
As on weight, I don't think hoping for a lighter Camaro is as big of a stretch as it was with the Mustang. The Mustang is basically the same size, and added IRS, new saftety equipment, a stiffer chassis, and larger brakes. The Camaro is not adding IRS, or brembos as those are already standard. There is of course possibly new crash/safety standards, but they are already starting on a proven modern platform. The Alpha platform that has already shown to be lighter than previous gen when you compare vehicles its being used in. Take for instance the new 2014 CTS on Alpha bases at 3,616 lbs, versus the 2013 model which based at over 3,800 lbs, and the new one actually grew in size a bit as well. The 2014 CTS V-Sport with the turbo V6 is the heaviest at over 3,900 lbs, where as the 2013 model was over 4,000 when you added in more options. So based on that alone, if the Camaro does not change in size at all, it should drop a little weight. Now there is evidence that the Camaro may shrink, and if so, that pretty much all buy guarantees a weight loss in my opinion. So that said, I don't think we are setting ourselves up for dissapointment similar to the new Mustang when it comes to weight.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
06-19-2014, 11:00 AM | #58 | |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
06-19-2014, 11:12 AM | #59 |
Right on, and another reason I didn't mention gearing ratios...because with new transmissions today having 8+ speeds, it changes what the end ratio really needs to be to have a good performance/efficency balance.
06-19-2014, 12:59 PM | #60 |
Drives: 21 Bronco Join Date: Jun 2012
I expect the camaro to lose some weight, I don't think it will be as drastic as some people in here think though.
06-19-2014, 02:15 PM | #61 | |
Drives: 2015 Camaro 1SS,6 Speed,NPP Exhaust Join Date: Dec 2012
It just came out in the news the other day, the 2015 Mustang GT will gain 85lbs over the previous model....Not the porker you were hoping for |
06-19-2014, 02:27 PM | #62 | |
As said in the quote I always assumed it would be about the same or gain up to 100 lbs. When they said up to 300 lbs I was shocked, but never believed it. Guess I was right. The early rumors said the Mustang would LOSE weight...which it did not. I even said there was no way GM would catch Ford in the weight department if the Mustang lost weight. But now that the Mustang has gained, I think GM can match or maybe even do better.
06-19-2014, 05:49 PM | #63 | |
Drives: 2020 LT1 Black Join Date: May 2013
It's kinda fascinating how serious this rivalry is. |
06-19-2014, 06:29 PM | #64 | |
Drives: 2018 ZL1 Join Date: Jun 2014
2.56 is a base model corvette 6l80 rear end ratio 2.72 for z51/Grand Sport 3.27 in the current Gen 5 Camaro 6l80 TR6070 in the '14 stingray corvette is 3.42 gears IMO Gearing in the Camaro will be similar to current gen so acceleration is similar in performance due to the higher weight than the Vette. |
06-19-2014, 07:45 PM | #65 | |
Yea Camaro & Mustang owners is like mixing oil & water. At some point a fist fight is gonna break out Ive owned both, I love both. I consider both to equal in my mind. The Mustang does some things better than the Camaro and vice versa. |
06-20-2014, 06:41 PM | #66 | |
Drives: 2012 Camaro 2SS Join Date: Feb 2012
06-20-2014, 08:00 PM | #67 |
Drives: 2010 ZR1 "Satan" Join Date: Nov 2013
The 2014 base 4 door Cadillac ATS weighs 3315lb at the curb.
I'd say a 3600lb V8 Camaro is viable. Wait, isn't that what my 2000 SS Camaro M6 weighed without the spare tire?
2002 Z06 "Blue Meanie" 11.36 ET
2003 Z06 in progress 2009 CTS-V "Spooky" 12.36 ET, bone stock at 1600 mi. Rainy day in Sacramento. Sadness. 2010 ZR1 "Satan" no times yet. 2013 Volt SCCA Solo2 #771 HS3. And a bunch of Duramaxes. Last edited by McRat; 06-20-2014 at 08:21 PM. |
06-20-2014, 08:02 PM | #68 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
You aren't honestly trying to compare a 4th gen F body to the next gen Alpha based Camaro, are you?
06-20-2014, 08:29 PM | #69 |
Drives: 2011 Camaro VR 2SS/RS & Impala Join Date: Apr 2013
What mandated backup camaras ! LOL..... ppl are getting lazy! What happen to. taking the time to look over your shoulder! This world is scary!
06-21-2014, 01:14 AM | #70 |
Drives: 2008 Malibu V6 Join Date: Mar 2008
Hey, I hear ya. As a rule, I'm against these sorts of government mandates too, but I think that few would argue that the current Camaro is the most lookin-over-your-shoulder-friendly car out there. This car has a lot of virtues, but great rear visibility isn't among them. In other words, if there are any cars out there that will become a bit safer due to this mandate, I suspect the Camaro is probably among them.
