TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 04-02-2012, 11:41 PM   #43
ucsbjones
Drives: 2011 SS Convert. Sierra White, Tan
my nose is a lil different
on the 2011 summit white -- but my strut towers are changing colors bigtime and it does not seem to be a deposit of anything. Is anyone else have a mocha colored strut tower now?
ucsbjones is offline   Reply With Quote
Old 04-23-2012, 03:33 PM   #44
fast34me
Drives: 2010 CGM 2SS/RS
CGM 2SS/RS doesn't match either. Hood, Fenders, Bumper cover, fuel door are all real noticeable, if you're looking for it. I washed mine yesterday and before it didn't seem to bother me, but now it's kinda aggravating me.
fast34me is offline   Reply With Quote
Old 05-31-2012, 06:25 PM   #45
Vintage-Iron
Drives: 2012 Chevrolet Camaro 1SS/RS
My SS is summit white built in January of 2012, matches perfectly all over...
Vintage-Iron is offline   Reply With Quote
Old 05-31-2012, 06:33 PM   #46
xx_ED_xx
xx_ED_xx's Avatar
Drives: 04 Silverado
Thanks nc sg ss i was curious what it looked like with the mirrors removed
xx_ED_xx is offline   Reply With Quote
Old 05-31-2012, 06:44 PM   #47
xx_ED_xx
xx_ED_xx's Avatar
Originally Posted by NHSS View Post
Even Ray Charles could see it doesn't match.
Awesome
Old 05-31-2012, 07:32 PM   #48
29er
29er's Avatar
Drives: 14 1LE Garage King
i don't understand why gm is letting the cars go at quality control with this..they see that the paint shade don't match and still they send them away..why they did not try other materials to make it match with the rest of the car???
why on the 4th gen paint is matching? you had steel,fiberglass, plastic..
i know the 5th gen they are kinda square with different angle it give contrast to the paint ..but i don't buy it. they should try to get a better quality paint on their product.look at the money you spend on them..
29er is offline   Reply With Quote
Old 09-18-2012, 08:44 PM   #49
Chevy69er
Chevy69er's Avatar
Drives: 2011 SLP ZL-585, 13' Silverado
The term that describes the apperant mismatched panels is called Metamorism. Color is merely the reflection of light. So different light sources provide a different shade of color just as mentioned on this thread. Its not a ' mismatch' or a 'flop' difference, merely the reflection of light off of two different angles of panels! Its perfectly illustrated in the GM service bulleton with the painted panel with the seam which changes colors when the adjacent panel angle is changed.
As for the bumper facias and fuel door being different colors is a mismatch which is better on some makes and models than others. Being a production painter for 25 years trust me when i tell you acura bumpers are by far the worst. Check them out next time you see one and youll be glad that GMs quality standards are better than Acura! The mismatch happens for several reasons. One is that the plastic parts follow a different refinishing procedure because they have extra steps to insure adhesion to the raw plastic. So they are painted in a different part of the factory or a different facility entirely. Both pose color match challenges. The biggest one is the fact that paint is pumped sometimes miles to different parts of the factory to the spraying robots. The longer the distance the more likely the heavier toners/metallics/pearls in the color settle to the bottom of the lines, effectively changing the original color that matched when it started at the pump! Another reason there is a slight color and flop mismatch especially on metallic colors is the fact that the metallics and micas lay different on plastic panels because plastic by nature collects more static electricity.
Its very diffecult to achieve a very good color match throughout entire car even when the car is sprayed my the same painter with the same gun/mix/pressure and technique! Ferrari is by far the best color match but there completly built/painted by hand by skilled technicians. $$$
Just my 2c to help clarify. BTW i have a summit white 2011 SLP585 and the front bumper matchs because they respray the front clip to ensure the hood matchs. Rear bumper and fuel door color is off but with what i know about the challenges the factory has with color match, im perfectly happy with the slight mismatch!
Chevy69er is offline   Reply With Quote
Old 10-11-2012, 11:37 PM   #50
crazy4camaro
Drives: 2012 RSLT,1979 Trans Am
depending on the angle I can count four different shades of "Summit white" on my 2012 it is a rainbow of whites ......
crazy4camaro is offline   Reply With Quote
Old 10-12-2012, 06:35 AM   #51
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
what about the perceived trash in my paint from the factory?
'19 Z06-7Speed and lowered on stock bolts
'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew
TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0
SOLD! '18 ZL1 Mosiac Blk
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 11-04-2012, 09:27 PM   #52
lsaterz28
the vetteman
lsaterz28's Avatar
Drives: 68Z/28,09G8/GT,11RS/SS VT,13GMC PU
we all can see that with several different colors ours is cyber gray met. the body panels are not flush and light will give different look on each panel, at the factory the entire car was painted at same time. i don't see how we can correct our eye sight. to make it look the same.
lsaterz28 is offline   Reply With Quote
Old 07-07-2013, 01:01 AM   #53
bluecam805
Team LFX
Drives: 2012 Camaro LS
So would most dealers warranty this color mismatch??
2.5" cat- back Magnaflow exhaust w. resonated x pipe, Roto Fab CAI .. .. JL sound system, Halo fog lights, Escort radar, window tint + turn signals
bluecam805 is offline   Reply With Quote
Old 07-17-2013, 01:16 PM   #54
Mydivorcegift
Future Mopar Owner
Mydivorcegift's Avatar
Drives: 2011, 2SS/RS, Synergy
Yes
2005 GTO-IBM-A4-Sold
2011 Camaro SS/RS Synergy-1 of 255-Sold
You will be missed but you are in good hands!
2019 Challenger Hellcat
B5, Redeye, Widebody
Mydivorcegift is offline   Reply With Quote
