02-24-2024, 12:26 PM | #1 |
Tuning Question
Is tune worth it with just cai and exhaust? I have an exhaust code so I would like to get that removed in a tune. Any 93 tune suggestions or should I have it dyno tuned? Im located in east tn around Knoxville. Thanks for any suggestions and insight on it.
02-24-2024, 12:41 PM | #2 |
Drives: 2016 2SS Convertible Join Date: May 2012
Not really. If you have e85 available then I would add that and then get a tune. What is the exhaust code? Do you know what is causing it?
02-24-2024, 12:51 PM | #3 |
02-24-2024, 12:53 PM | #4 | |
Drives: Car Join Date: May 2023
What do you mean by exhaust? Axleback? Catback? Full system w/ headers? |
02-24-2024, 12:55 PM | #5 |
02-24-2024, 01:05 PM | #6 |
Here is a thread on that trouble code. Sounds like an installation problem with the exhaust.
https://www.camaro6.com/forums/showthread.php?t=600204 |
02-24-2024, 01:20 PM | #7 | |
02-24-2024, 02:21 PM | #8 | |
02-24-2024, 05:01 PM | #9 |
Drives: 2SS 1LE Join Date: Oct 2011
The CAI will bypass the stock intake noise silencing, making it louder, so it'll definitely have more power because it will be louder.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
