03-14-2017, 10:44 PM | #1 |
Drives: Hyper blue 1ss Join Date: Mar 2017
Wider tires
Thinking about getting wider rear tires, i like the look and keeps the car planted better when launching. Any ideas on which tires size to go with and im guessing ill have to get rid of the OEM rims ?
03-14-2017, 11:17 PM | #2 |
Drives: 2016 2ss Join Date: Jun 2016
I have eagle f1 g2, 305s in the back 285 in the front. No rubbing or trouble other than gravel sticking to them.
2016 Black Camaro 2SS A8 Red interior
Modifications:Red powder coated Whipple LT1 blower, Aeroforce interceptor w/vent pod, FI Interchiller, Roto-Fab breather, ARH full length headers with high flow cats, JRE AFM modules, Borla S type NPP exhaust, Mishimoto catch can, JMS fuel pump voltage booster,MRR 017 1LE replica rims, 285/35zr20 Goodyear Eagle F1 G:2 front, Toyo r888r 325/30/zr20 back, Phastek blackout kit for the reflectors, GM dark tail lamps, Blendmount radar detector mount with Escort Redline hardwired in. |
03-15-2017, 01:55 AM | #3 |
Drives: 1970 Vette,16 1SS, 07 Ford Taurus Join Date: Aug 2015
I have 305/30/20s on 20x 11 wheels in the rear and 285/30/20 on 20 x10 wheels on the front. I think Chevy should have done a better job with wheel and tire sizes from the start. 245s on the front is a joke and 275 in the back a joke also. Chevy should have had wider wheels to start with and never put anything less than a 295 in the rear. I have no rubbing issues or anything with about 9500 miles on the wheels and tires.
03-15-2017, 03:12 AM | #4 |
My setup:
Wheels: MRR M228 (2015 Z-28 Replicas) Front – 20 x 9 Rear – 20 x 10 Tires: Nitto NT05 Front – 275/35/20 Rear – 305/30/20 Ride Height: Stock, Not Lowered ZERO rubbing or traction issues with my stone-stock LT1 A8 Camaro. But, NT05 tires are LOUD if that kind of thing is an issue for you. Last edited by TenSeven; 03-15-2017 at 03:14 AM. Reason: Speeling Erorrs. |
03-15-2017, 07:01 AM | #5 | |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
I have been pricing replacement sets for my 1LE and it looks like I will be around the $2k range for a decent set of tires, most SS owners would have a stroke if they had to pay $2k every 10k-15k miles for tires. |
03-15-2017, 07:38 AM | #6 |
Drives: 2019 ZL-1 Join Date: Feb 2009
This is discussed in the tire section. 305 's in the rear is the widest.
2012 Yukon XL Denali w/ 6.2 AWD |
03-15-2017, 07:45 AM | #7 |
Drives: 2016 Z06 coupe Join Date: Dec 2016
03-15-2017, 03:43 PM | #8 |
A Heartbeat Away.........
Drives: Not As Fast As I Would Like To Join Date: Mar 2016
I couldn't find the thread that talked about it, but I thought 305s could rub a wiring harness and destroy it. I think some guy that lives in the desert had that issue.
2016 Hyper Blue Metallic 2SS | A8 | MRC | Sunroof | Nav | Mishimoto Catch Can | GM CAI | Hurst Shifter | Borla S-Type Exhaust | Body Color Splash Guards | 1LE Splitter | GM Dark Tail Lights | ZL1 Third Brake Light | Custom Fuel Door, Badges & Bowties | Oracle Side Markers | Blacked Out Stuff | Opti-Coat Pro+ The problem with this world is stupidity. I'm not saying there should be penalties for stupidity, but why don't we just take the warning labels off everything and let the problem solve itself. |
03-15-2017, 04:41 PM | #9 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Cali is indeed a desert! 305/35 will rub through, 305/30 will be fine.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
03-15-2017, 06:00 PM | #10 |
Black lightning
[QUOTE=enzia35;9615785]Cali is indeed a desert! 305/35 will rub through, 305/30 will be fine.[/QUOTE
Wont front wheel spacers fix that.? I think the gap with 30 will be to much if not lowered
[ 2021 Camaro ZLE 10 speed
03-15-2017, 06:17 PM | #11 |
03-15-2017, 07:30 PM | #12 |
All kinds of info in the Wheels and tires section.
03-15-2017, 10:35 PM | #13 |
I am sure there will be 325 tire and 12x19" wheel offerings soon enough... considering the ZL1 1LE is prowling around now. Although you could just do 315 R888s or R888Rs with 5mil spacers if tread wear doesn't concern you too much
2016 Camaro 2SS M6- Garage
03-16-2017, 08:10 PM | #14 |
Drives: 2017 50th SS convertible Join Date: Oct 2016
Hello,
This is my set up with the 1LE rims that I ordered through GM. The dealer picked out the sizes for me and said that these will not rub when making very hard U-Turns. It's possible to go wider, as evidenced by the reports of others and that GM also uses wider tires but those are Good Years and not all tires are made the same despite the use of similar numbers. I love the Nitto Tires. The rears are slightly taller than stock (which are actually smaller than the fronts when stock). Kindest, Donner |
