12-12-2017, 04:04 PM | #85 | |
Drives: 2017 ZL1 A10 Join Date: Jul 2014
I went with the K080842HD belt. I did so because USP45 mentioned he had slip with that belt and the 9.17" pulley. But others have mentioned they don't have any slip. So I figure a 1/4" shorter belt shouldn't hurt anything. |
12-12-2017, 04:09 PM | #86 |
One more thing. Lots of people going with the HD (heavy duty green back) belts. Gates came out with a newer improved series called RPM which is apparently better suited for a supercharger.
There is a K080845RPM available. Quote from Gates on another forum: RPM (Racing, Performance, Muscle) is a new, no compromise belt built specifically for supercharged applications. Whereas 99% of all belts on the market today use a polyester tensile cord, the RPM series uses an aramid tensile cord. This is the same fiber found in bulletproof vests and is 10x stronger than steel and 5x less elastic than polyester. When polyester heats up (which it does even from normal use) it will stretch out. As you can imagine, when that belt stretches out you experience belt slip and boost loss. Eventually the elastic properties of the polyester will fail and the belt that was once 100” will stretch to 100.25”, at which point the tensioner can no longer compensate for the stretch and generally results in belt failure. Due to the strength and minimal elasticity of aramid fiber, the RPM series of belts will not stretch which allows the belt to maintain its true length throughout its service life. This results in more consistent boost and in some instances, users have reported a 1-2psi increase merely from switching from HD belts to RPM belts. We actually have some user submitted under hood video on our Instagram page (GatesRPM) that clearly demonstrates the difference between polyester and aramid corded belts. Another main benefit of the RPM line is the use of two layers of adhesion gum. These layers create a sandwich around the tensile cords which transfers the load to the strongest part of the belt; the jacket (or smooth backside of the belt). FleetRunner HD belts got a reputation for strength because they use one layer of adhesion gum, standard micro-v belts forgo any adhesion gum. RPM belts also utilize a patented rubber compound with the highest coefficient of friction available and are built in common OE supercharger sizes as well as many sizes used with aftermarket setups. The RPM line has expanded to 299 part numbers with new numbers being added every quarter. |
12-12-2017, 04:20 PM | #87 | |
Drives: 2018 ZL1 A10 Nightfall Gray Join Date: Apr 2016
What a racket! |
12-12-2017, 04:39 PM | #88 | |
Drives: '18 Zl1. '18 GT350. Join Date: Dec 2016
Still waiting on wheels. Once those come in, BMR's get installed, car gets settled in. Then we go fuel and cam and blow shit out the park and add nitrous.
There's only 2 people I trust. 1 of them is me, the other's not you. 2018 Zl1. 1199 RWHP/931 TQ.
12-12-2017, 05:06 PM | #89 | |
12-12-2017, 07:18 PM | #90 |
Dyno Show Queen LOL
Well I can't stand a shop to over charge on parts.. most these shop don't take the time to setup accounts so they source from Texas speed, marryland speed, or Bryan tooley.. then they add 20 percent.. or they don't buy the volume..
Also I hate paying for work and parts when I can do it.. I modded 3 cars In last 2 years about brok lol
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber Last edited by EDFHOBBIES; 12-12-2017 at 08:45 PM. |
12-12-2017, 08:33 PM | #91 |
Ran those on my Vette. Honestly, we don't even need to upgrade wires, but I wanted them changed anyways, so I said just get me a set.
12-12-2017, 10:32 PM | #92 |
My SS made 670 with a 2300? Why wait for the 2650. I ran 10.33@135 with a 2300. Its wicked fast with more to come once I get the Lt4 injectors and we should be at 740 rwhp with the 70mm pulley.
12-12-2017, 10:58 PM | #93 | |
Thank you Al Oppenheiser!
Not a racket. Business.
So if RL lost that shipment and paid the freight claim to compensate for the lost goods, then RL bought those parts. If they later find the lost shipment, then they have stuff they rightfully own. What would you do if you were RL? Yep, you'd probably ask Whipple if they want to buy them back again. When they say no, you'd be stuck selling it on Ebay. |
12-13-2017, 05:44 AM | #94 | |
Dyno Show Queen LOL
The 2650 would add 100 hp plus just by itself with out messing with headers and cai ect. Just take off and install it .6k for blower minus selling your lt4 blower (zl1 owner) for 1500 to 2k comes out pretty cheap plus room to grow. A lot cheaper than the lingenfelter kit (pulley, cai, belt, crank bolt, damper) $1200, 1200 to 2000k for headers, then a tune.. Plus room to grow... 2650 will move the most air cooler. Rather have new technology and not waste 6k on the 2300 for that much money. That's pretty good my manual 6 5th gen TT ran that at royal purple a good track Hennessy track was in 11s .. if your doing that in a auto your slow.
12-21-2017, 12:43 AM | #95 | |
Drives: Camaro ZL1 Join Date: Oct 2017
Care to explain this then?! |
12-21-2017, 04:57 PM | #96 | |
12-21-2017, 08:52 PM | #97 |
12-22-2017, 01:44 AM | #98 |
Literally every other vendor advertises 9.17" as 15% also. Look at Innovators West who manufactures their own dampeners and uses Metco pulleys. Or better yet call ATI they're who actually designs and makes the pulleys not Vengeance or Lingenfelter.
