TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Tuning / Diagnostics -- engine and transmission
Old 03-13-2016, 12:24 AM   #1
GSoccerCam
Drives: 2010 LS3
305 to the wheels.. wtf why
out of 3 pulls.. I got 305 to the wheels in my 2012 camaro ss automatic with kooks long tubes 1 7/8 inch with a cold air intake and it being tuned.. oh yeah dynod on a mustang dyno... I know these normals aren't where they should be... they should be around 370 right ?
2010 LS3 FORGED BOTTOM END. BUILT TOP END WITH BTR COMPONENTS AND A GPI CAM
GSoccerCam is offline   Reply With Quote
Old 03-13-2016, 12:26 AM   #2
GSoccerCam
Drives: 2010 LS3
what could be the reasoning behind such low numbers......
Old 03-13-2016, 12:38 AM   #3
LBreezie
LBreezie's Avatar
Drives: 2012 Camaro 45th anniversary
Get a cam if you want 370 to the wheels.
LBreezie is offline   Reply With Quote
Old 03-13-2016, 12:46 AM   #4
rvadim76
Drives: SOLD: 2012 Chevy Camaro 2SS
yeah, those numbers are way too low.
Why don't you try another dyno? How does your car run like? What's you 0-60 time etc?
I would think about fuse pull but you said you got a tune..maybe wrong gas?
Keep us posted bud, good luck!
rvadim76 is offline   Reply With Quote
Old 03-13-2016, 12:46 AM   #5
GSoccerCam
Drives: 2010 LS3
ive talked to people who have done the same mods as me and are getting 370....
Old 03-13-2016, 01:19 AM   #6
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
I posted here once..so i thought. Your about 70 rwhp or so short..im 360 rwhp and 400ft lbs torque with my mods.
rontammy0 is offline   Reply With Quote
Old 03-13-2016, 04:10 AM   #7
ticowarbird
BOHIC
ticowarbird's Avatar
Drives: 2010 Camaro SS "Enola"
Thought I posted too....
I thought I posted here too... Anyway... After ARH LTs, Vararam intake, and I tune I got 371 to the wheels. Cam and ported heads got me to 450, somethings off.
What else can I do to my Camaro?
ticowarbird is offline   Reply With Quote
Old 03-13-2016, 10:29 AM   #8
GSoccerCam
Drives: 2010 LS3
thanks. and I don't have any 0-60 times since any mods.. but I always use 93 nothing else.. also I accidently posted in transmission forums. i cant figure out how to delete it though sorry about that.
and my car runs fine... it doesn't do anything that stands out.... it sort of suprised me how low the numbers were /:
could something be causing it not to get the full power ?? compression? knock?
Old 03-13-2016, 11:03 AM   #9
bleavens1962
Drives: 2014 1LS Camaro
What kind of tune, you did not specify ?
Many V6 guys run HP or IPF
Is there another shop you can get your car dyno'd at that has the same brand dyno ?
Start at the dyno readings first, might not be the car..
bleavens1962 is offline   Reply With Quote
Old 03-13-2016, 04:02 PM   #10
GSoccerCam
Drives: 2010 LS3
Dyno Steve tuned it for me through SCT ii x4 .. hes gonna check out my data logs.. i believe its the dyno. but hes kind enough to check my data logs to make sure nothings going on
Old 03-13-2016, 04:54 PM   #11
qcman
qcman's Avatar
Drives: 2013 Camaro 2SS RDP Tuned L99
Steve is great! And will go out of his way to help you out. I would think its the dyno perhaps the dyno guy can provide you with some comparable car's numbers as it would show if they were all on the low side too. I really doubt your car is anywhere that low.
qcman is offline   Reply With Quote
