07-14-2015, 10:17 AM | #43 |
That's what I was thinking. Back near the exhaust pipes too which Baylor thinks might be one of the issues with the C7. Even with inlets for air, that can't be very efficient. I'm thinking the location on the 6th gen will work much better being in front of the engine heat and with higher pressure air coming in through the grille. Just a guess though.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
07-14-2015, 10:26 AM | #44 |
Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
Okay, I have confimed that the Corvette transmission cooler is in the back of the car. Here is a link to a thread that has a video in it. At about the 5:10 mark, the guy talks about the transmission/differential cooling. Take a look:
http://www.stingrayforums.com/forum/...ues-track.html So, that means the Camaro transmission cooler is a completely different setup altogether than the Corvette. |
07-14-2015, 10:37 AM | #45 | |
Dances With Mustangs
Since it looks like they're adding a completely separate cooler just for the automatic trans, that adds more weight than just the difference between the auto and the manual. And it would make sense that the driver-side auxiliary cooler (of the 3 separate ones) would connect to the oil pan in/out ports (which are on the same side) for engine oil cooling. If the main center cooler is for engine water, then the passenger side cooler could be for the manual trans. Separate coolers for engine water, engine oil and trans oil would definitely do a better job than just trying to keep everything cool with an engine water radiator. The auto trans must get a lot hotter than the manual if they need an additional cooler for it.
Blue Angel is here!! 1SS/RS LS3 M6 IBM |
07-14-2015, 10:39 AM | #46 |
It is not a dry sump setup. You can see the cooling plates attached to the oil pan. In a dry sump, there is no big pan like that. But what I am not sure about is how the cooling is provided. Are those two ports for transmission oil to go out to a radiator, or are those two ports for engine coolant to come into the plates to provide cooling. If it is the latter, there would be no radiator for the oil cooling system.
07-14-2015, 10:47 AM | #47 | |
07-14-2015, 11:05 AM | #48 |
From everything shared, the 3 radiators are just for engine coolant since they shrunk the size of the radiator from the 5th gen. A 4th auto trans cooler is just behind the center radiator (in a horizontal position) and the engine oil cooler is the exact same as seen on the LT4 cutaway.
07-14-2015, 11:10 AM | #49 | |
Drives: 13 Elantra Coupe(not for long!) Join Date: May 2015
07-14-2015, 11:20 AM | #50 | |
07-14-2015, 11:21 AM | #51 |
Indeed... call it "sumpthing else" lol
07-14-2015, 11:23 AM | #52 | |
07-14-2015, 11:32 AM | #53 | |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
07-14-2015, 12:01 PM | #54 |
the current Camaro's LS3 has a similar engine oil cooler.
as well as the LSA the LT1 will have it as well... so its safe to say that the Camaro will have the same setup. so that's one cooler out of the way. I also have read that the three radiators are for engine coolant and separate coolers will be present for other fluids such as transmission and oil. |
07-14-2015, 02:05 PM | #55 | |
07-14-2015, 02:08 PM | #56 |
Or is it just the cooling plates aren't installed on the one picture we have of the LT1 Camaro engine? Need more pictures of the SS for sure.
